USG Flex 700 @ 1Gbps
Pook
Pook Posts: 130
First Answer First Comment Friend Collector Nebula Gratitude
I have the above on a FTTP 1 Gbps internet connection but can only get around 520Mbps with UTM enabled. Speed rises to around 700Mbps with all security disabled but this appliance is rated @ 1350Mbps so something is wrong. Anti-Malware is in Express mode!
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034
    edited September 2021
    @Pook
    The throughput will be affect when you enable the Firewall or UTM profiles.
    Since the firewall need to check and analyze each packet, therefore,  it will consume numerous performance.
    Also, disable traffic statistic, and BWM since it could effect the throughput as well.(On-Premise)
    On the datasheet, the maximum throughput@1350Mbps is measured based on (1,460-byte HTTP packets) and test done by multiple pairs.(Wan and Lan are one pair)
  • Pook
    Pook Posts: 130
    Thanks Charlie, where can I disable Traffic statistics and what is BWM?
  • Pook
    Pook Posts: 130
    I have another Flex 700 arriving today to go on another site that has a 1Gbps connection. I will run some speed tests and update the results here.
Nebula Tips & Tricks
