ChromeCast not working
benni347
We have a Zyxel AX7501-B0 and our TV in the meetingroom is using a
Chromecast device that was working with our previous router. We did a
factory reset on the Chromecast before changing the router. Once the AX7501-B0 was installed and everything was up and running, we tried to
activate the Chromecast again, but it is impossible to get the device
working because when I try to connect my Chromecast with WiFi it doesn't connect, any idea on how I could fix that?
Hello @benni347
The following article might help you, https://support.google.com/chromecast/answer/7331010?hl=en-GB , as it seems like ChromeCast can only support one WiFi network at a time.
- so you probably need to make your Chromecast device forget your old WiFi network.
- then you might be able to make it connect to your new router.
Kind regards,
Tony0
Hello @benni347
Kind regards,
Tony0 -
Hello @tonygibbs16
Thanks for your response. As it turned out, we had a Raspi running in the network, which also served as a DHCP server.
After turning it off, all is working well.
Cheers,
benni347
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
