Secomea Sitemanager connecting issues
joel_lallemand
Hi all
We are trying to connect a secomea sitemanager 3529 on a LAN-Port on a GS1920-24 Switch. We never had problems connecting a sitemanager on different switch types. But the port on the zyxel switch suddenly goes down after connecting... Even there's no port-sec configured. Any ideas? Logs only shoes port down and up events.
Firmware on the GS1920 is V.4.3.0.a
Thanks for your help.
Best regards
Joel
Hi @joel_lallemand,
Welcome to Zyxel community!
Have you tried to configure port speed with force 100M full-duplex or 10M full-duplex on both secomea sitemanager 3529 and GS1920-24?
The configuration page for the port speed on GS1920 is Basic setting > Port Setup.
(You will need to access GS1920 via WebGUI)
May you also share the complete firmware version of your GS1920-24?
It can be found in the status page.
(The screenshot below is just an example in the user guide.)
Hi Jason
Thanks for you feedback.
We already tried that without success.
We have installed a cisco switch between the sitemanager and the zyxel switch - now it works fine. I also assume a negotiation problem between the other two devices.
Best regards
Joël0 -
Hi @joel_lallemand,
It seems like an IOP issue between the sitemanager 3529 and GS1920.
Thanks for sharing the workaround you found here.
- 588 USG FLEX H Series
- 476 News and Release
