LTE firmware for SBG3600
Hi @hojdy,
Because it get the incorrect value to display status bar in previous version, and we fixed it since AAZE.8.
Does the SBG3600-N support Zyxel LTE modems? They are not listed in supported modems list.0 -
What are the LTE settings for Elisa network in Finland?0
Hi @Sakari,
The LTE configuration as below, APIN code is a key to a SIM card, If PIN code authentication is enabled on the inserted SIM card, enter the 4-digit PIN code provided by your ISP to unlock the SIM card. As for APN settings, select this option to get the APN automatically from the service provider.
Can you please send the firmware for me as well, thank you!0
May have I the newest firmware for LTE, Mine is down after an upgrade to: LTE FW : ALT3100_05_00_02_00_81_MS
modem FW: V1.00(AAKO.9)
Hi @Aldrich14
LTE firmware version ALT3100_05_00_02_00_81_MS is the latest one.
Hi
Cloud you please send me the newest lte firmware too?
Steffen
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
