nebula route for all internet traffic
Hi @FabrizioF,
Welcome to Zyxel Community!
May I comfirm your question is that you would like to make all devices under NSG50 to access the Internet via VPN site to site (Non-Nebula VPN peers)?
If so, you may configure a policy route "Type VPN, Src IP any, Dst IP (peer LAN IP address)" on NSG50 and configure a policy route "VPN, Src IP any, Dst IP (NSG LAN IP address) on peer site.
Also, configure a policy route on peer site to make all the subnets under NSG50 are able to surf the Internet.Adam
Thanks Adam for the replyI did not understoond well if I have to do the route policy on both firewall or only on the NSG50.From the site where the NSG50 is, I want to direct all internet traffic to the non-Zyxel firewallthanks again0
@FabrizioF,
You have to configure the route policy on both site.
If you only configure it on NSG50 to make all traffic to non-nebula firewall, while no policy is set to the non-nebula firewall, traffic from NSG50 via VPN tunnel does not know where to go back.Adam
Hi Adam, i have created route policy on NSG50 but not on the other firewall (through which all internet traffic will go out). His support has said me that isn't necessary.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
