GS1900-24 and VLAN ID 1
Hello Everbody!
I have a question regarding VLAN ID1 on my Zyxel switch.
As there seams to be an issue when using VLAN ID1 with my Sophos UTM I would like to diasable (and if possible remove) VLAN ID1 on my Zyxel switch and use ID10 instead. Unfortunalty as soon as I remove all ports from ID1 (set to excluded) and move to ID 10 (untagged) instead the communication stops. What is the reason for this? All information I found on the web is always using VLAN ID1.
Thank you!
Volker
Best Answers
Hi @VoRe,
Since the VLAN1 can't be deleted, you just need to set VLAN1 to "Excluded" or "Forbidden" for every port to avoid receiving VLAN1 packet.1
Hi @VoRe,
Welcome to Zyxel Community!
I think the reason is that you only changed the VLAN port setting but you didn't change the PVID and the egress setting might not correct.
I suggest to set one port's PVID from 1 to 10 before you change VLAN setting, this allow you can access switch Web GUI after you change VLAN setting.
May you also share your VLAN setting(port and VLAN port setting) and topology?
Hello! Attached some screenshots. I tried again a few minutes agop. As soon as I change the PVID from 1 to 10 I can't access the Webgui of the GS1900-24 any more. On port 1 and port 2 I have connected two more Zyxel switches in another part of the building (2x GS1900-8HP). Do you need some more details?
Best regards
Thanks for the answer.. this solved my problem. I expected something like this but I overlooked this option. Is it necessarry/possible to delete VLAN1 (can't delete it)? Or is it OK to just set VLAN1 to "Excluded" for every port?
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
