Setting static IP address
13»
  • ComputeInTheCloud
    ComputeInTheCloud Posts: 19 image  Freshman Member
    First Comment Friend Collector Nebula Gratitude Fifth Anniversary
    Hi @ComputeInTheCloud
    We checked your AP's diaginfo, the communication between AP and Nebula shows these findings.
    Nebula checked AP's ip status failed. AP is unable to connect Nebula.
    The needed ports for Nebula management are ports 4335, 6667.
    We can take a look into your ATP500’s configurations and logs.
    Can you collect diagnostics of ATP500 and download its startup.conf at MAINTENANCE then send me via private message?
    Thank you
    Regards,
    Bella
    If you can explain what 'diagnostics' you need and how to collect them and give me an email address I may be able to accommodate your request.
  • Zyxel_Bella
    Zyxel_Bella Posts: 560 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    Here is the path to collect information:
    At MAINTENANCE page > Diagnostics > click Collect Now > the file will show in Files tab once done.
    And download startup-config.conf at File Manager for use to check your firewall rule such as port settings or IP/MAC bindings.
    Thank you
    Regards,
    Bella
  • ComputeInTheCloud
    Thank you
    Regards,
    Bella
    Bella,
    You had stated that you would give me an email address to send these files to. Have you provided that?
  • Zyxel_Vic
    Zyxel_Vic Posts: 323 image  Zyxel Employee
    25 Answers First Comment Friend Collector Eighth Anniversary
    From your ATP500 settings, we saw that you had enabled IP/MAC Binding on MPTC_LAN_70, this feature will block those un-authorized IP/MAC address binding which may lead to certain result you saw. Please turn this feature off and have a try again.
    PeterUK Posts: 4,446 image  Guru Member
    But if you have IP/MAC Binding on you can add the AP MAC and IP out side of the DHCP range should work.
  • ComputeInTheCloud
    This did fix the issue. I guess I do not understand what IP/Mac binding is. I thought it was the ability to set DHCP reservations for devices. Obviously that is incorrect.
Nebula Tips & Tricks
