NWA1123ACv3 managed mode
IT_Field_Support
IT_Field_Support Posts: 97 image  Ally Member
edited May 2024 in Wireless
We bought 6 NWA1123ACv3 access point thinking they will replace the NWA1123ACv2 but it seems that we cannot manage this new modèle from USG40w.
Please is there a way to make the NWA1123ACv3 manageable capwap mode with the USG40W ?
Thanks !!
  • Zyxel_Bella
    Zyxel_Bella Posts: 560 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    Hi @IT_Field_Support
    The NWA1123ACv3 supports NebulaFlex, giving you the ability to easily switch between standalone and Nebula cloud central management.
    Although the NWA1000 Series can’t be managed by AP controller but both of NWA1123ACv3 and ACv2 can be managed by Nebula Control Center.
    We also suggest to deploy NWA1123ACv3 rather than ACv2 for enjoying with new hardware, firmware version and features such as remote access on Nebula.
    If you only consider to manage APs with an on-premises controller, the WAC500 is suggested for a complex one that requires advanced features such as Collaborative Detection & Response (CDR)        and Remote AP (RAP).
    Thank you
    Regards,
    Bella
