NSA325 (v1) - migrating from a single disk to a new disk
hoverdonkey
hoverdonkey Posts: 11
First Anniversary
edited November 2021 in Personal Cloud Storage
Hi
I have an NSA325 with a single (nearly full) 3TB disk which I want to change for a single new 6TB disk.
Can I install the new 6TB disk in the empty bay and then migrate the shares from the 3TB disk, i.e. so I do not have to set up access/NFS again?  Or do I have set up shares on the new 6TB disk then copy files?
  • Mijzelf
    Mijzelf Posts: 2,395
    250 Answers 1000 Comments Friend Collector Fifth Anniversary
    You'll have to setup new shares. Internally the share points to a directory on a volume, and as you are using another volume, the old share won't work anymore.
  • hoverdonkey
    First Anniversary
    Thanks for confirming.
