[NEBULA] Firewall rules?
The device of NSG50, comparing to zyxel firewalls such as USG20-VPN, this one seemed equipped far simple function.
When I got this new one, I was so excited to install and set it. I was connected the the NCC platform, it was my curiosity that was it all the function? The firewall rule it provided was so simple, no flexibility and sometimes not function normally.
I was tried to convince myself that maybe I am not familiar its function, but I couldn't find the setting I needed it.
Is it because this one just offered the basic function?
Hello @royThe nebula producntion is aim to the small/medium business scope, hence it is much easier to use and deployment.But we are still planing more advance feature in the nearly future.So, please stay tuned in our official site
May I know which setting you need? when you mention "I couldn't find the setting I needed it."5
May I know which setting you need? when you mention "I couldn't find the setting I needed it."5 -
Thank you very much for your help!
Are you having a plan to make source/destination host/group address as alias names adding somewhere in NCC, so we can clearly set in the firewall rule? IP address is very hard to remember....0 -
Hello~
Besides making the source/destination host/group addresses as alias/nickname, if it can have a check box to disable or enable the rule would be perfect!0 -
@roy
Do you mean the address/group object when you mentioned about the (source/destination host/group addresses as alias/nickname)?
BTW, about the checkbox, it is already in our roadmap, believe it will be implemented, in the nearly future!!0 -
Yes, address/group object is what I meant. It is great it is on the way. I am looking forward the new system coming soon.
Thank you for the attention!
@roy
Got it, currently it is not in our roadmap, yet.
However, I will move this request to our ideas section, thanks for your suggestion.
Everyone who think this feature is required, please click like in below!!
Adding to this, please add this! price wise, the NSG 100-200 is almost the same as your USG/competion firewalls, and it is lacking options that makes me ask the following: Will this customer need more advance options, if unsure, buy Cyberoam/sophos or USG series.
Nebula is way too good to good of an idea just to be dumped down the road, because options are not added.2 -
Hi @Alfr
Thanks for the suggestion! As mentioned by Chris, we strive for an easy of use keeping in mind Nebula customer targets. We are gradually adding some of the advanced features but most likely from another approach that will make it less complicated to use
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
