NBG7815 - Unable to register the product ?
gnivat
gnivat Posts: 15
Hi there,
I am not able to register my NBG7815 on
The answer is "Device not found"
Anyone able to register an Armor G5 on Zyxel websites?
Thant's!
«1
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 855
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 50 Answers 500 Comments
    Hi @gnivat
    The NBG6818 and NBG7815 can register on https://mycloud.zyxel.com/?locale=zh-TW
  • gnivat
    gnivat Posts: 15
    Hello Jerry, it does not work, the search device button does nothing and when registering manually, the answer is "not found" !
  • Podo
    Podo Posts: 28  Freshman Member
    When you setup your device for the first time it will redirect you to login to zyxel account.
    If setup is successful it will register your device on your account.
  • gnivat
    gnivat Posts: 15
    I guess I am not able to find the MAC address and the Serial Number.
    So how should work the Search Devices ?
    It does nothing for me ?
  • Podo
    Looks like clouds are not able to register Armor devices.
    However you can download Zyxel Armor app for your smartphone if you want to manage it or something.
    Just search for "Zyxel Armor"
  • gnivat
    gnivat Posts: 15
    The time fly but Armor G5 is still as bad as 6 monts ago !
    Still cannot be registered as a Zyxel product :)
    And the Zyxel Armor app is very useless
  • Zyxel_Jerry
    Hi @gnivat
    The NBG6818 and NBG7815 can register on https://mycloud-sso.zyxel.com
    When login NBG6818 and NBG7815 it will register an account on the PCloud.
    You can login the device by using the PCloud account to access the device.
    The NBG6818 and NBG7815 are not able to register on https://portal.myzyxel.com/  or
  • gnivat
    gnivat Posts: 15
    Hello Jerry,
    Unfortunatly, I cannot use the PCloud account to access the device as I had to set it in Bridge mode.
    The standard mode is too unstable and without the possibility to backup/resaure a config I prefere not use it as a router.
    Honestly, I don't understand why this Zyxel product cannot be registered with the other zyxel products on https://portal.myzyxel.com/
    Thanks,
    Guillaume
  • Zyxel_Jerry
    Hi @gnivat
    The two websites belongs to different product categories and which are targeting to different users.
    So we manage licenses in different places.
  • gnivat
    gnivat Posts: 15
    Hi Jerry,
    Do you know the concept of User Experience @ Zyxel ?
    Because, as a user, I don't understand what you are talking about.
    I just see that this Zyxel product cannot be registered as a Zyxel product.
    How can I use PCloud when the device is setup in Bridge mode ?
    Thanks,
    Guillaume
