Adopt to Nebula remotely
TAPTech
TAPTech Posts: 174 image  Master Member
First Comment Friend Collector Seventh Anniversary Nebula Gratitude
Is it possible to adopt ATP200 to Nebula remotely?  I am able to go through the process of applying the default-config to the ATP200, but when using the Nebula link, it states that I need to physically press the reset button as the firewall is not in the default state.  Perhaps there is a CLI command I can run via SSH instead?
  • Zyxel_Emily
    Reset the device to factory default settings
    Administrator must locally apply factory default settings by pressing reset button of firewall panel before switching to cloud mode. Only the following settings may be changed and still allow firewall to switch to cloud mode:
    1. Default admin account’s password
    2. WAN settings
  • Zyxel_Emily
    2. WAN settings
