Fast roaming doesn't work with DPPSK
Hi @dempie
After looking into your settings, we setup a same environment and the case can be reproduced.
We’re investigating the root cause and will fix it asap.
Before solution released, pleased disable 11r as a workaround.
Sorry for causing inconvenience and thanks for concerning the issue.
Regards,
Bella
Hi @dempie
Thank you for reporting the observation.
Please enable the Zyxel support at Help > Support request > Invite Zyxel support as administrator, and provide the Org and Site name for us to check.
We’ll check the conditions and update you once the information confirmed.
Regards,
Bella
Hi @Zyxel_BellaZyxel_Bella said:Hi @dempie
Regards,
Bella
thank you for looking into that case. Good to know support is very fast.
Best Regards,
dempie0 -
Hi @Zyxel_Bella,
does new version V6.30(ABTF.0) of AP firmware solve fast roaming problem?
Thanks.
Regards, dempie0 -
Hi @dempie
Sorry for the late reply, the fix of DPPSK vlan problem with fast roaming not yet been in time to be released in the version V6.30P0C0.
https://community.zyxel.com/en/discussion/12462
But good news is the solution has been found, we can help you upgrade to date firmware once you provide the schedule for us to apply.
Please enable the Zyxel support at Help > Support request > Invite Zyxel support as administrator, and provide the Org and Site name.
It’s fine if you want to wait the official release included the solution.
Feel free to let us know. Thank you!
Regards,
Bella
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
