mellanox 25G eth card on xs1930-10 by sfp28
Hi @xs1930,
Welcome to Zyxel Community!
From the port status image, we can see that port 9 is not even link up.
After investigating the network card and SFP you used, I notice that the Mellanox 4121A is able to perform 10G, but not for RTXM330-005. Seems that the SFP is only support 25G, so please ensure this SFP is backward compatibility to 10G.
In addition, you may consider Zyxel SFP which demonstrates in our switch datasheet.
For 10G, we have SFP 10G-SR and 10G-LR.
Hope it helps.Adam1
Thanks a lot ! I changed my cable with a 10G dac copper,then the eth card works . Now I konw the sfp28 cable could not auto-negotiation to sfp+, even the eth card and switcher can.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
