NAS540 degraded disk, tried repair, now volume down
Kuno
I got a disk in the RAID 5 array, that went offline with a lot of "command timeouts". After a reboot of the NAS, it came back online, and teh NAS suggested that I repaired the volume. So I did that, and now the volume is down! there have not been anymore "command timeouts" on the problem disk.
I'm hopping someone has an idea, to how, if possible, I can get the array up and running.
Here is output from:
mdadm --examine /dev/sd[abcde]3
mdadm: cannot open /dev/sda3: No such device or address
/dev/sdb3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : f0577b65:283a8be2:235c4865:251ac2c8
Name : NAS540:2 (local to host NAS540)
Creation Time : Wed Apr 7 08:01:04 2021
Raid Level : raid5
Raid Devices : 4
Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)
Array Size : 11708660736 (11166.25 GiB 11989.67 GB)
Data Offset : 262144 sectors
Super Offset : 8 sectors
State : clean
Device UUID : 14739b23:eaeee6f1:5d90fda3:d4c43395
Update Time : Wed Dec 8 00:13:41 2021
Checksum : 39e6164e - correct
Events : 524
Layout : left-symmetric
Chunk Size : 64K
Device Role : Active device 0
Array State : AA.. ('A' == active, '.' == missing)
/dev/sdc3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
Raid Devices : 4
State : clean
Device UUID : 8700f0d6:21358560:6ab88d29:7556bb54
Checksum : a0f0a3a6 - correct
Events : 524
Chunk Size : 64K
Device Role : Active device 1
/dev/sdd3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
Raid Devices : 4
State : clean
Device UUID : c0749a62:d560b5a8:0fcb26d4:46c23d65
Checksum : 2fe6c20d - correct
Events : 524
Chunk Size : 64K
Device Role : spare
/dev/sde3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
Raid Devices : 4
Array Size : 11708660160 (11166.25 GiB 11989.67 GB)
Used Dev Size : 7805773440 (3722.08 GiB 3996.56 GB)
State : clean
Device UUID : c48a0e1b:48ca0d7c:72cd77a4:03fe7e41
Update Time : Tue Dec 7 20:46:47 2021
Checksum : 68494d74 - correct
Events : 474
Chunk Size : 64K
Device Role : Active device 3
Array State : AAAA ('A' == active, '.' == missing)
Best Answers
I'm sorry to be a pain in your but, Mijzelf, but I can't find a share menu. Only the share section in control panel, where the shares are marked "lost". I can't do anything to them there. Is there another place, where I can access a shares menu?0
In 'Control Panel'->'Privilege and Sharing'->'Shared Folders' all 'flat directories' in the volumes are listed as 'disabled'. You can enable them via the 'Edit share' icon.But now I see the given volume name is not the hexcode, but some user supplied name. As that name is stored on the filesystem, it is possible that the 'lost' shares hide the 'disabled' shares, as they are on different volumes, which yet have the same names. Confusing.To solve this you can change the user supplied volume name:cd /i-data/sysvol/.system/echo "Your own volume name" >name_labelreboot0
Can you also post the SMART values?smartctl -a /dev/sdasmartctl -a /dev/sdb...Two disks are dropped from the array, so now it's down. It might be possible to rebuild it degraded from 3 disks, depending on the damage of the disk. "Command timeouts" can point to a serious problem, so it's better not to include that disk in the array.
Hi Mijzelf.
It looks like /dev/sda is a USB disk, I have attached!
smartctl -a /dev/sda:
Model Family: Western Digital Caviar Green (AF, SATA 6Gb/s)Device Model: WDC WD30EZRX-00MMMB0Serial Number: WD-WCAWZ1741961LU WWN Device Id: 5 0014ee 2b11bd91bFirmware Version: 80.00A80User Capacity: 3,000,592,982,016 bytes [3.00 TB]Sector Sizes: 512 bytes logical, 4096 bytes physicalDevice is: In smartctl database [for details use: -P show]ATA Version is: ATA8-ACS (minor revision not indicated)SATA Version is: SATA 3.0, 6.0 Gb/s (current: 1.5 Gb/s)Local Time is: Thu Dec 9 09:43:53 2021 GMTSMART support is: Available - device has SMART capability.SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===SMART Status command failed: scsi error medium or hardware error (serious)SMART overall-health self-assessment test result: PASSEDWarning: This result is based on an Attribute check.
General SMART Values:Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled.Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run.Total time to complete Offlinedata collection: (49200) seconds.Offline data collectioncapabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported.SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer.Error logging capability: (0x01) Error logging supported. General Purpose Logging supported.Short self-test routinerecommended polling time: ( 2) minutes.Extended self-test routinerecommended polling time: ( 473) minutes.Conveyance self-test routinerecommended polling time: ( 5) minutes.SCT capabilities: (0x3035) SCT Status supported. SCT Feature Control supported. SCT Data Table supported.
SMART Attributes Data Structure revision number: 16Vendor Specific SMART Attributes with Thresholds:ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 150 139 021 Pre-fail Always - 9475 4 Start_Stop_Count 0x0032 093 093 000 Old_age Always - 7663 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 071 071 000 Old_age Always - 21356 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 096 096 000 Old_age Always - 4503192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 428193 Load_Cycle_Count 0x0032 184 184 000 Old_age Always - 48029194 Temperature_Celsius 0x0022 123 093 000 Old_age Always - 29196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1No Errors Logged
SMART Self-test log structure revision number 1No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testingSelective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk.If Selective self-test is pending on power-up, resume after 0 minute delay.
smartctl -a /dev/sdb:Model Family: Seagate NAS HDDDevice Model: ST4000VN000-1H4168Serial Number: Z304CYC1LU WWN Device Id: 5 000c50 07ba1cae3Firmware Version: SC46User Capacity: 4,000,787,030,016 bytes [4.00 TB]Sector Sizes: 512 bytes logical, 4096 bytes physicalRotation Rate: 5900 rpmForm Factor: 3.5 inchesDevice is: In smartctl database [for details use: -P show]ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3bSATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)Local Time is: Thu Dec 9 09:45:36 2021 GMTSMART support is: Available - device has SMART capability.SMART support is: Enabled=== START OF READ SMART DATA SECTION ===SMART overall-health self-assessment test result: PASSEDGeneral SMART Values:Offline data collection status: (0x00) Offline data collection activitywas never started.Auto Offline Data Collection: Disabled.Self-test execution status: ( 0) The previous self-test routine completedwithout error or no self-test has everbeen run.Total time to complete Offlinedata collection: ( 107) seconds.Offline data collectioncapabilities: (0x73) SMART execute Offline immediate.Auto Offline data collection on/off support.Suspend Offline collection upon newcommand.No Offline surface scan supported.Self-test supported.Conveyance Self-test supported.Selective Self-test supported.SMART capabilities: (0x0003) Saves SMART data before enteringpower-saving mode.Supports SMART auto save timer.Error logging capability: (0x01) Error logging supported.General Purpose Logging supported.Short self-test routinerecommended polling time: ( 1) minutes.Extended self-test routinerecommended polling time: ( 510) minutes.Conveyance self-test routinerecommended polling time: ( 2) minutes.SCT capabilities: (0x10bd) SCT Status supported.SCT Error Recovery Control supported.SCT Feature Control supported.SCT Data Table supported.SMART Attributes Data Structure revision number: 10Vendor Specific SMART Attributes with Thresholds:ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE1 Raw_Read_Error_Rate 0x000f 106 099 006 Pre-fail Always - 109276723 Spin_Up_Time 0x0003 093 092 000 Pre-fail Always - 04 Start_Stop_Count 0x0032 086 086 020 Old_age Always - 150815 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 07 Seek_Error_Rate 0x000f 079 060 030 Pre-fail Always - 878438849 Power_On_Hours 0x0032 041 041 000 Old_age Always - 5216410 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 012 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 82184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0190 Airflow_Temperature_Cel 0x0022 071 046 045 Old_age Always - 29 (Min/Max 22/31)191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 46193 Load_Cycle_Count 0x0032 093 093 000 Old_age Always - 15081194 Temperature_Celsius 0x0022 029 054 000 Old_age Always - 29 (0 18 0 0 0)197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0SMART Error Log Version: 1No Errors LoggedSMART Self-test log structure revision number 1No self-tests have been logged. [To run self-tests, use: smartctl -t]SMART Selective self-test log data structure revision number 1SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS1 0 0 Not_testing2 0 0 Not_testing3 0 0 Not_testing4 0 0 Not_testing5 0 0 Not_testingSelective self-test flags (0x0):After scanning selected spans, do NOT read-scan remainder of disk.If Selective self-test is pending on power-up, resume after 0 minute delay.0
smartctl -a /dev/sdc:Device Model: ST4000DM004-2CV104Serial Number: ZTT0AK1SLU WWN Device Id: 5 000c50 0c7f6500aFirmware Version: 0001User Capacity: 4,000,787,030,016 bytes [4.00 TB]Sector Sizes: 512 bytes logical, 4096 bytes physicalRotation Rate: 5425 rpmForm Factor: 3.5 inchesDevice is: Not in smartctl database [for details use: -P showall]ATA Version is: ACS-3 (unknown minor revision code: 0x006d)SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)Local Time is: Thu Dec 9 09:47:58 2021 GMTSMART support is: Available - device has SMART capability.SMART support is: Enabled=== START OF READ SMART DATA SECTION ===SMART overall-health self-assessment test result: PASSEDGeneral SMART Values:Offline data collection status: (0x00) Offline data collection activitywas never started.Auto Offline Data Collection: Disabled.Self-test execution status: ( 0) The previous self-test routine completedwithout error or no self-test has everbeen run.Total time to complete Offlinedata collection: ( 0) seconds.Offline data collectioncapabilities: (0x73) SMART execute Offline immediate.Auto Offline data collection on/off support.Suspend Offline collection upon newcommand.No Offline surface scan supported.Self-test supported.Conveyance Self-test supported.Selective Self-test supported.SMART capabilities: (0x0003) Saves SMART data before enteringpower-saving mode.Supports SMART auto save timer.Error logging capability: (0x01) Error logging supported.General Purpose Logging supported.Short self-test routinerecommended polling time: ( 1) minutes.Extended self-test routinerecommended polling time: ( 497) minutes.Conveyance self-test routinerecommended polling time: ( 2) minutes.SCT capabilities: (0x30a5) SCT Status supported.SCT Data Table supported.SMART Attributes Data Structure revision number: 10Vendor Specific SMART Attributes with Thresholds:ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE1 Raw_Read_Error_Rate 0x000f 078 064 006 Pre-fail Always - 604176143 Spin_Up_Time 0x0003 096 096 000 Pre-fail Always - 04 Start_Stop_Count 0x0032 098 098 020 Old_age Always - 26515 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 07 Seek_Error_Rate 0x000f 075 060 045 Pre-fail Always - 348393329 Power_On_Hours 0x0032 094 094 000 Old_age Always - 5971 (82 189 0)10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 012 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 14183 Runtime_Bad_Block 0x0032 086 086 000 Old_age Always - 14184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0190 Airflow_Temperature_Cel 0x0022 070 053 040 Old_age Always - 30 (Min/Max 25/33)191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 11193 Load_Cycle_Count 0x0032 098 098 000 Old_age Always - 5484194 Temperature_Celsius 0x0022 030 047 000 Old_age Always - 30 (0 19 0 0 0)195 Hardware_ECC_Recovered 0x001a 078 064 000 Old_age Always - 60417614197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 1910 (135 191 0)241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 18980119668242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 10442242758SMART Error Log Version: 1No Errors LoggedSMART Self-test log structure revision number 1No self-tests have been logged. [To run self-tests, use: smartctl -t]SMART Selective self-test log data structure revision number 1SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS1 0 0 Not_testing2 0 0 Not_testing3 0 0 Not_testing4 0 0 Not_testing5 0 0 Not_testingSelective self-test flags (0x0):After scanning selected spans, do NOT read-scan remainder of disk.If Selective self-test is pending on power-up, resume after 0 minute delay.0 -
smartctl -a /dev/sdd:Device Model: ST4000DM004-2CV104Serial Number: ZFN386QQLU WWN Device Id: 5 000c50 0c58ef733Firmware Version: 0001User Capacity: 4,000,787,030,016 bytes [4.00 TB]Sector Sizes: 512 bytes logical, 4096 bytes physicalRotation Rate: 5425 rpmForm Factor: 3.5 inchesDevice is: Not in smartctl database [for details use: -P showall]ATA Version is: ACS-3 (unknown minor revision code: 0x006d)SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)Local Time is: Thu Dec 9 09:51:23 2021 GMTSMART support is: Available - device has SMART capability.SMART support is: Enabled=== START OF READ SMART DATA SECTION ===SMART overall-health self-assessment test result: PASSEDGeneral SMART Values:Offline data collection status: (0x00) Offline data collection activitywas never started.Auto Offline Data Collection: Disabled.Self-test execution status: ( 0) The previous self-test routine completedwithout error or no self-test has everbeen run.Total time to complete Offlinedata collection: ( 0) seconds.Offline data collectioncapabilities: (0x73) SMART execute Offline immediate.Auto Offline data collection on/off support.Suspend Offline collection upon newcommand.No Offline surface scan supported.Self-test supported.Conveyance Self-test supported.Selective Self-test supported.SMART capabilities: (0x0003) Saves SMART data before enteringpower-saving mode.Supports SMART auto save timer.Error logging capability: (0x01) Error logging supported.General Purpose Logging supported.Short self-test routinerecommended polling time: ( 1) minutes.Extended self-test routinerecommended polling time: ( 506) minutes.Conveyance self-test routinerecommended polling time: ( 2) minutes.SCT capabilities: (0x30a5) SCT Status supported.SCT Data Table supported.SMART Attributes Data Structure revision number: 10Vendor Specific SMART Attributes with Thresholds:ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE1 Raw_Read_Error_Rate 0x000f 076 064 006 Pre-fail Always - 376712383 Spin_Up_Time 0x0003 096 096 000 Pre-fail Always - 04 Start_Stop_Count 0x0032 098 098 020 Old_age Always - 28435 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 07 Seek_Error_Rate 0x000f 076 060 045 Pre-fail Always - 389445539 Power_On_Hours 0x0032 094 094 000 Old_age Always - 6055 (160 134 0)10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 012 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 18183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0188 Command_Timeout 0x0032 100 099 000 Old_age Always - 4295032833189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0190 Airflow_Temperature_Cel 0x0022 069 052 040 Old_age Always - 31 (Min/Max 25/34)191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 18193 Load_Cycle_Count 0x0032 098 098 000 Old_age Always - 5822194 Temperature_Celsius 0x0022 031 048 000 Old_age Always - 31 (0 20 0 0 0)195 Hardware_ECC_Recovered 0x001a 076 064 000 Old_age Always - 37671238197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 2058 (152 164 0)241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 13829940399242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 16497836234SMART Error Log Version: 1No Errors LoggedSMART Self-test log structure revision number 1No self-tests have been logged. [To run self-tests, use: smartctl -t]SMART Selective self-test log data structure revision number 1SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS1 0 0 Not_testing2 0 0 Not_testing3 0 0 Not_testing4 0 0 Not_testing5 0 0 Not_testingSelective self-test flags (0x0):After scanning selected spans, do NOT read-scan remainder of disk.If Selective self-test is pending on power-up, resume after 0 minute delay.0
smartctl -a /dev/sde:Model Family: Seagate NAS HDDDevice Model: ST4000VN000-1H4168Serial Number: Z304TRANLU WWN Device Id: 5 000c50 086d991d0Firmware Version: SC46User Capacity: 4,000,787,030,016 bytes [4.00 TB]Sector Sizes: 512 bytes logical, 4096 bytes physicalRotation Rate: 5900 rpmForm Factor: 3.5 inchesDevice is: In smartctl database [for details use: -P show]ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3bSATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)Local Time is: Thu Dec 9 09:53:36 2021 GMTSMART support is: Available - device has SMART capability.SMART support is: Enabled=== START OF READ SMART DATA SECTION ===SMART overall-health self-assessment test result: PASSEDSee vendor-specific Attribute list for marginal Attributes.General SMART Values:Offline data collection status: (0x00) Offline data collection activitywas never started.Auto Offline Data Collection: Disabled.Self-test execution status: ( 0) The previous self-test routine completedwithout error or no self-test has everbeen run.Total time to complete Offlinedata collection: ( 97) seconds.Offline data collectioncapabilities: (0x73) SMART execute Offline immediate.Auto Offline data collection on/off support.Suspend Offline collection upon newcommand.No Offline surface scan supported.Self-test supported.Conveyance Self-test supported.Selective Self-test supported.SMART capabilities: (0x0003) Saves SMART data before enteringpower-saving mode.Supports SMART auto save timer.Error logging capability: (0x01) Error logging supported.General Purpose Logging supported.Short self-test routinerecommended polling time: ( 1) minutes.Extended self-test routinerecommended polling time: ( 496) minutes.Conveyance self-test routinerecommended polling time: ( 2) minutes.SCT capabilities: (0x10bd) SCT Status supported.SCT Error Recovery Control supported.SCT Feature Control supported.SCT Data Table supported.SMART Attributes Data Structure revision number: 10Vendor Specific SMART Attributes with Thresholds:ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE1 Raw_Read_Error_Rate 0x000f 100 099 006 Pre-fail Always - 246779663 Spin_Up_Time 0x0003 093 092 000 Pre-fail Always - 04 Start_Stop_Count 0x0032 087 087 020 Old_age Always - 141595 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 07 Seek_Error_Rate 0x000f 079 060 030 Pre-fail Always - 876492969 Power_On_Hours 0x0032 041 041 000 Old_age Always - 5206610 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 012 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 85184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0187 Reported_Uncorrect 0x0032 028 028 000 Old_age Always - 72188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0190 Airflow_Temperature_Cel 0x0022 069 041 045 Old_age Always In_the_past 31 (2 66 35 22 0)191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 50193 Load_Cycle_Count 0x0032 093 093 000 Old_age Always - 14159194 Temperature_Celsius 0x0022 031 059 000 Old_age Always - 31 (0 20 0 0 0)197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 8198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 8199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0SMART Error Log Version: 1ATA Error Count: 72 (device log contains only the most recent five errors)CR = Command Register [HEX]FR = Features Register [HEX]SC = Sector Count Register [HEX]SN = Sector Number Register [HEX]CL = Cylinder Low Register [HEX]CH = Cylinder High Register [HEX]DH = Device/Head Register [HEX]DC = Device Command Register [HEX]ER = Error register [HEX]ST = Status register [HEX]Powered_Up_Time is measured from power on, and printed asDDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,SS=sec, and sss=millisec. It "wraps" after 49.710 days.Error 72 occurred at disk power-on lifetime: 52043 hours (2168 days + 11 hours)When the command that caused the error occurred, the device was active or idle.After command completion occurred, registers were:ER ST SC SN CL CH DH-- -- -- -- -- -- --40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455Commands leading to the command that caused the error were:CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name-- -- -- -- -- -- -- -- ---------------- --------------------60 00 08 00 00 00 40 00 1d+03:30:32.423 READ FPDMA QUEUED60 00 f8 ff ff ff 4f 00 1d+03:30:32.396 READ FPDMA QUEUED60 00 00 ff ff ff 4f 00 1d+03:30:32.396 READ FPDMA QUEUED60 00 00 ff ff ff 4f 00 1d+03:30:32.395 READ FPDMA QUEUED60 00 00 ff ff ff 4f 00 1d+03:30:32.395 READ FPDMA QUEUEDError 71 occurred at disk power-on lifetime: 52043 hours (2168 days + 11 hours)When the command that caused the error occurred, the device was active or idle.After command completion occurred, registers were:ER ST SC SN CL CH DH-- -- -- -- -- -- --40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455Commands leading to the command that caused the error were:CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name-- -- -- -- -- -- -- -- ---------------- --------------------60 00 00 ff ff ff 4f 00 1d+03:30:28.014 READ FPDMA QUEUED60 00 00 ff ff ff 4f 00 1d+03:30:28.013 READ FPDMA QUEUED60 00 00 ff ff ff 4f 00 1d+03:30:28.013 READ FPDMA QUEUED60 00 08 ff ff ff 4f 00 1d+03:30:27.931 READ FPDMA QUEUED60 00 08 ff ff ff 4f 00 1d+03:30:27.931 READ FPDMA QUEUEDError 70 occurred at disk power-on lifetime: 52043 hours (2168 days + 11 hours)When the command that caused the error occurred, the device was active or idle.After command completion occurred, registers were:ER ST SC SN CL CH DH-- -- -- -- -- -- --40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455Commands leading to the command that caused the error were:CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name-- -- -- -- -- -- -- -- ---------------- --------------------60 00 00 ff ff ff 4f 00 1d+03:30:23.473 READ FPDMA QUEUED60 00 00 ff ff ff 4f 00 1d+03:30:23.472 READ FPDMA QUEUED60 00 00 ff ff ff 4f 00 1d+03:30:23.472 READ FPDMA QUEUED60 00 00 ff ff ff 4f 00 1d+03:30:23.471 READ FPDMA QUEUED60 00 00 ff ff ff 4f 00 1d+03:30:23.471 READ FPDMA QUEUEDError 69 occurred at disk power-on lifetime: 52043 hours (2168 days + 11 hours)When the command that caused the error occurred, the device was active or idle.After command completion occurred, registers were:ER ST SC SN CL CH DH-- -- -- -- -- -- --40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455Commands leading to the command that caused the error were:CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name-- -- -- -- -- -- -- -- ---------------- --------------------60 00 08 08 10 3d 40 00 1d+03:30:19.050 READ FPDMA QUEUED60 00 08 00 10 3d 40 00 1d+03:30:19.049 READ FPDMA QUEUED60 00 08 70 0f 7a 40 00 1d+03:30:19.049 READ FPDMA QUEUED60 00 08 00 0f 7a 40 00 1d+03:30:19.049 READ FPDMA QUEUED60 00 08 00 10 3d 40 00 1d+03:30:19.045 READ FPDMA QUEUEDError 68 occurred at disk power-on lifetime: 52043 hours (2168 days + 11 hours)When the command that caused the error occurred, the device was active or idle.After command completion occurred, registers were:ER ST SC SN CL CH DH-- -- -- -- -- -- --40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455Commands leading to the command that caused the error were:CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name-- -- -- -- -- -- -- -- ---------------- --------------------60 00 08 ff ff ff 4f 00 1d+03:30:14.556 READ FPDMA QUEUED60 00 08 ff ff ff 4f 00 1d+03:30:14.535 READ FPDMA QUEUED60 00 08 ff ff ff 4f 00 1d+03:30:14.535 READ FPDMA QUEUED60 00 08 ff ff ff 4f 00 1d+03:30:14.535 READ FPDMA QUEUED60 00 08 ff ff ff 4f 00 1d+03:30:14.535 READ FPDMA QUEUEDSMART Self-test log structure revision number 1No self-tests have been logged. [To run self-tests, use: smartctl -t]SMART Selective self-test log data structure revision number 1SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS1 0 0 Not_testing2 0 0 Not_testing3 0 0 Not_testing4 0 0 Not_testing5 0 0 Not_testingSelective self-test flags (0x0):After scanning selected spans, do NOT read-scan remainder of disk.If Selective self-test is pending on power-up, resume after 0 minute delay.0
USB disk is removed now. Here is a new output of
mdadm --examine /dev/sd[abcd]3/dev/sda3:Magic : a92b4efcVersion : 1.2Feature Map : 0x0Array UUID : f0577b65:283a8be2:235c4865:251ac2c8Name : NAS540:2 (local to host NAS540)Creation Time : Wed Apr 7 08:01:04 2021Raid Level : raid5Raid Devices : 4Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)Array Size : 11708660736 (11166.25 GiB 11989.67 GB)Data Offset : 262144 sectorsSuper Offset : 8 sectorsState : cleanDevice UUID : 14739b23:eaeee6f1:5d90fda3:d4c43395Update Time : Wed Dec 8 00:13:41 2021Checksum : 39e6164e - correctEvents : 524Layout : left-symmetricChunk Size : 64KDevice Role : Active device 0Array State : AA.. ('A' == active, '.' == missing)/dev/sdb3:Magic : a92b4efcVersion : 1.2Feature Map : 0x0Array UUID : f0577b65:283a8be2:235c4865:251ac2c8Name : NAS540:2 (local to host NAS540)Creation Time : Wed Apr 7 08:01:04 2021Raid Level : raid5Raid Devices : 4Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)Array Size : 11708660736 (11166.25 GiB 11989.67 GB)Data Offset : 262144 sectorsSuper Offset : 8 sectorsState : cleanDevice UUID : 8700f0d6:21358560:6ab88d29:7556bb54Update Time : Wed Dec 8 00:13:41 2021Checksum : a0f0a3a6 - correctEvents : 524Layout : left-symmetricChunk Size : 64KDevice Role : Active device 1Array State : AA.. ('A' == active, '.' == missing)/dev/sdc3:Magic : a92b4efcVersion : 1.2Feature Map : 0x0Array UUID : f0577b65:283a8be2:235c4865:251ac2c8Name : NAS540:2 (local to host NAS540)Creation Time : Wed Apr 7 08:01:04 2021Raid Level : raid5Raid Devices : 4Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)Array Size : 11708660736 (11166.25 GiB 11989.67 GB)Data Offset : 262144 sectorsSuper Offset : 8 sectorsState : cleanDevice UUID : c0749a62:d560b5a8:0fcb26d4:46c23d65Update Time : Wed Dec 8 00:13:41 2021Checksum : 2fe6c20d - correctEvents : 524Layout : left-symmetricChunk Size : 64KDevice Role : spareArray State : AA.. ('A' == active, '.' == missing)/dev/sdd3:Magic : a92b4efcVersion : 1.2Feature Map : 0x0Array UUID : f0577b65:283a8be2:235c4865:251ac2c8Name : NAS540:2 (local to host NAS540)Creation Time : Wed Apr 7 08:01:04 2021Raid Level : raid5Raid Devices : 4Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)Array Size : 11708660160 (11166.25 GiB 11989.67 GB)Used Dev Size : 7805773440 (3722.08 GiB 3996.56 GB)Data Offset : 262144 sectorsSuper Offset : 8 sectorsState : cleanDevice UUID : c48a0e1b:48ca0d7c:72cd77a4:03fe7e41Update Time : Tue Dec 7 20:46:47 2021Checksum : 68494d74 - correctEvents : 474Layout : left-symmetricChunk Size : 64KDevice Role : Active device 3Array State : AAAA ('A' == active, '.' == missing)0 -
OK, it looks like your last disk was causing the timeout errors, as it has a lot of READ FPDMA QUEUED errors, and it was dropped from the array first.
So let's see if the array can be rebuilded without it. The command to create a new array around the existing filesystem is
mdadm --stop /dev/md2
mdadm --create --assume-clean --level=5 --raid-devices=4 --metadata=1.2 --chunk=64K --layout=left-symmetric /dev/md2 /dev/sda3 /dev/sdb3 /dev/sdc3 missing
That are two lines each starting with mdadm. The first command can error out, it is not clear to me if the array is up or not.
Using this command the USB disk should not be connected. (It's not actually a problem, but the disk device names can be different)
It said that there an exiting array, should it create a new one? I wrote "y" and now I have a Volume 1 with disk 1,2 and 3, and it is marked orange and Zyxel says it's degraded and I should repair, but there is no repair button. Should I have said no, to create a new array? Disk 4 is marked with status red and as hotspare in Zyxels overview.
New output:mdadm --examine /dev/sd[abcd]3/dev/sda3:Magic : a92b4efcVersion : 1.2Feature Map : 0x0Array UUID : 8beaf982:073ce48c:da730e41:7c327a55Name : NAS540:2 (local to host NAS540)Creation Time : Fri Dec 10 17:18:14 2021Raid Level : raid5Raid Devices : 4Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)Array Size : 11708660160 (11166.25 GiB 11989.67 GB)Used Dev Size : 7805773440 (3722.08 GiB 3996.56 GB)Data Offset : 262144 sectorsSuper Offset : 8 sectorsState : cleanDevice UUID : a131151d:27b790bf:ef167a59:a6501257Update Time : Fri Dec 10 17:31:40 2021Checksum : aa032c24 - correctEvents : 78Layout : left-symmetricChunk Size : 64KDevice Role : Active device 0Array State : AAA. ('A' == active, '.' == missing)/dev/sdb3:Magic : a92b4efcVersion : 1.2Feature Map : 0x0Array UUID : 8beaf982:073ce48c:da730e41:7c327a55Name : NAS540:2 (local to host NAS540)Creation Time : Fri Dec 10 17:18:14 2021Raid Level : raid5Raid Devices : 4Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)Array Size : 11708660160 (11166.25 GiB 11989.67 GB)Used Dev Size : 7805773440 (3722.08 GiB 3996.56 GB)Data Offset : 262144 sectorsSuper Offset : 8 sectorsState : cleanDevice UUID : 5f079e22:03e7208e:ed360eef:76c7bfa7Update Time : Fri Dec 10 17:31:40 2021Checksum : 645dc88e - correctEvents : 78Layout : left-symmetricChunk Size : 64KDevice Role : Active device 1Array State : AAA. ('A' == active, '.' == missing)/dev/sdc3:Magic : a92b4efcVersion : 1.2Feature Map : 0x0Array UUID : 8beaf982:073ce48c:da730e41:7c327a55Name : NAS540:2 (local to host NAS540)Creation Time : Fri Dec 10 17:18:14 2021Raid Level : raid5Raid Devices : 4Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)Array Size : 11708660160 (11166.25 GiB 11989.67 GB)Used Dev Size : 7805773440 (3722.08 GiB 3996.56 GB)Data Offset : 262144 sectorsSuper Offset : 8 sectorsState : cleanDevice UUID : 9d97bd47:8000d692:ccef5a0f:15e162b6Update Time : Fri Dec 10 17:31:40 2021Checksum : bd2244c7 - correctEvents : 78Layout : left-symmetricChunk Size : 64KDevice Role : Active device 2Array State : AAA. ('A' == active, '.' == missing)/dev/sdd3:Magic : a92b4efcVersion : 1.2Feature Map : 0x0Array UUID : f0577b65:283a8be2:235c4865:251ac2c8Name : NAS540:2 (local to host NAS540)Creation Time : Wed Apr 7 09:01:04 2021Raid Level : raid5Raid Devices : 4Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)Array Size : 11708660160 (11166.25 GiB 11989.67 GB)Used Dev Size : 7805773440 (3722.08 GiB 3996.56 GB)Data Offset : 262144 sectorsSuper Offset : 8 sectorsState : cleanDevice UUID : c48a0e1b:48ca0d7c:72cd77a4:03fe7e41Update Time : Tue Dec 7 20:46:47 2021Checksum : 68494d74 - correctEvents : 474Layout : left-symmetricChunk Size : 64KDevice Role : Active device 3Array State : AAAA ('A' == active, '.' == missing)0 -
Can you access your data? It is expected behavior that the array is degraded. It's a 4 disk array build from 3 disks. The 4th disk was dropped for a reason, it (or the slot it is in) has severe hardware errors.I think you have no repair button because you have no empty disks. The one which seems eligible (sdd) also seems to be member of another array.sdd has to be replaced, I think, but if this is your only copy of the data I think you should backup first. It's not clear why sdc was dropped, causing your initial problem. Maybe it's caused by some interference with sdd, when you tried to re-add sdd to the array, but it might also have an error not listed by SMART, which will blow your array again when you add a 4th disk.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
