Can no longer connect via SMB (Port 445) to NSA325-v2
martimus
Hi, for some reason I can no longer connect via SMB (Port 445) to my NAS (NSA325-v2) --> same issue with several windows 10 laptops.
I've updated the NAS to Samba 3.6.25 to support SMB2. To be on the safe side I've also activated SMB1.0 for the windows 10 laptops (control panel, turn on windows features, SMB1.0)
When mapping a network drive to a NAS share (in the same way I did it in the past) I get the following error:
'The remote device or resource won't accept the connection.'
The detailed error message says: 'The device or resource (192.168.0.3) is not set up to accept connections on port "The File and printer sharing (SMB)".
I can the NAS with its IP address via http (web interface) and ftp --> successful connection.
I also tried to connect via telnet to 192.168.0.3 445 --> same error, no connection.
Do you have an idea what the issue could be?
Long shot: you installed the 'zyxel-samba-replacement' package. There is some known bug, the installer is supposed to create an /opt/var/run symlink to /tmp (or /run, does that exist?), and for some reason that sometimes fails, in which case smbd doesn't start. Have a look at it.
Hi, thank you for the quick replay and the hint. I've uninstalled the 'zyxel-samba-replacement' package and now it works again
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
