Router model EMG2926: How to open ports
Ali2
Ali2 Posts: 2 image  Freshman Member
Home hosting setup need open All ports in this picture. Where in my Xytel EMG2926 control panels can i do this?
  • Ali2
    My Xytel panel (French)
  • Zyxel_CPE
    Zyxel_CPE Posts: 30 image  Freshman Member
    5 Answers First Comment Third Anniversary
    If there has any function you would like to config but it doesn't show on the GUI under your current access privilege, you could try to contact your local ISP they may help you to check it.
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    edited December 2021
    Bonjour @Ali2
    There is a user guide manual for EMG2926-Q10A router at https://fccid.io/pdf.php?id=2197013
    Section 14.3 talks about how to set-up Port Forwarding, under the Network->NAT part of the firmware.
          Réseau -> NAT
    I hope that this is helpful.
    Kind regards,
          Tony
