Windows 10 Secuextender 4.0.4 cannot connect to USG110
Hi, anybody can help me ? On one notebook with Win10 now Secuextender cannot connect fo our server. Secuextender and Tap client is enabled and installed.
I think it will be Win10 problem ...
on log is :
SecuextenderHelper.log :
on log is :
[ 2021/12/15 17:51:58 ][SecuExtender Helper] Request(88): REMOVE 0/2873532501 15 4294967295 4294967295
[ 2021/12/15 17:51:58 ][SecuExtender Helper] Remove Routing
[ 2021/12/15 17:51:58 ][SecuExtender Helper] Remove prioritize routing
[ 2021/12/15 17:51:58 ][SecuExtender Helper] Get netsh path = powershell
[ 2021/12/15 17:51:58 ][SecuExtender Helper] ia is null
[ 2021/12/15 17:51:58 ][SecuExtender Helper] Failed to read from client(2): 109, 0
[ 2021/12/15 17:51:58 ][SecuExtender Helper] Start to Disconnect pipe...
[ 2021/12/15 17:51:58 ][SecuExtender Helper] Shutting down a pipe connection instance...
SecuExtender.log (QQQ i change for security):
[ 2021/12/15 17:51:37 ][SecuExtender Agent][INFO] [VPN_QQQ] try to login qqq.qqq:40801
[ 2021/12/15 17:51:37 ][SecuExtender Agent][INFO] Connect to 1436567211:40801
[ 2021/12/15 17:51:58 ][SecuExtender Agent][ERROR] Cannot connect to device. 10060 (0x274c)
[ 2021/12/15 17:51:58 ][SecuExtender Agent][ERROR] Connect socket failed. (0x0)
[ 2021/12/15 17:51:58 ][SecuExtender Agent][ERROR] Failed to connect to device(1) (0x0)
[ 2021/12/15 17:51:58 ][SecuExtender Agent][ERROR] user login device failed (0x0)
[ 2021/12/15 17:51:58 ][SecuExtender Agent][DEBUG] SSL Connection is going to be closed
[ 2021/12/15 17:51:58 ][SecuExtender Agent][DETAIL] Connection ends.
On debug log USG110 i cannot seen anything for this connection try.
FW USG110: V4.65(AAPH.1)ITS-WK32-r101108
Thanks for help !!
Vaclav
Thanks for help !!
Vaclav
Best Answers
Hi @kyssling,When creating an address group object, you have to select the address type for it. That is, one address group object contains one address type only.
Thank you, is it possible to set access to USG for Geography object Czechia + foreign IP address? How? Thanks for help! I add images for better explanation ...
Hi, I created new security policy, where is the restriction on IP adress.
So we have (for example) Policy 1 to Czech (Destination etc) and now Policy 2 (to IP adress from foreign country) ... Thanks for help !
SecuExtender 4.0.4 is running fine under W10, also under 21H2 fully updated.Since your log is showing socket errors I would recommend to uninstall followed by a reinstallation of SecuExtender. Take care that you install it under full Administrator Account, not only "run as Administrator".0
Hi thanks for tips i try reinstall and write result ...
So now is everthing OK without reinstall. It was my mistake, colleague was abroad, i adding new geolocation from "Austria" on security policy. But after new FW I must Add Wiz_SSLVPN_Trusted_GEOIP_1 too ... But i dont see on Log any Blocked info ...Anybody knew if is possible ADD only IP address from abroad ? If i knew for example public IP, i adding only this IP and Geolocation on this UP still blocked ?
Try to add a new policy, allow the IP address from abroad, and set the priority higher than the Geolocation one.
Otherwise consider to create a group with GeoIP and Public IP addresses
Is this possible create type of group with where I can add geography and IP adress ? When i create new group with type "Geography" i can add only geography items. When i crete new group with adress type i can add only IP types ...mMontana said:Otherwise consider to create a group with GeoIP and Public IP addresses
- 441 Beta Program
- 293 Service & License
