I cant setup dualband... USG20W-VPN Router
Our small uncommercial organization just bought a USG20W-VPN Router.
I have reaaly trouble setting up this router....
First of all, I try to setup a Wifi. It works fine with a 2.4Ghz-band.
Also I'd like to setup another SSID / band with 5Ghz...
I succeeded setting up a new SSID - but..... this is also 2.4Ghz... where do we do that?
Please, I hope you can help us. Our TV does only have a 5 GHz network-adapter...
Best regards
Carsten
carjuth
Best regards
Carsten
carjuth
USG20W-VPN is single radio so you can have it operate on either 2.4Ghz or 5Ghz but not both.
Ted
Its a pity .... Im glad that you could tell me that :-)0
Is that still the case with the USG20W-VPN? Will it only connect on 2.4 and 5 even with two profiles?0
I don't think so, you'll need to add external zyxel ap (managed by USG20W-VPN) to support this0
- 588 USG FLEX H Series
- 477 News and Release
