Where I can get actual firmware for VMG3625-T50B?
PetrF
Hi there,
I can not find any newer one then currently used, the V5.50(ABPM.0)C0. But according https://www.zyxel.com/support/DNSpooq.shtml version 6 is approaching.
ftp://ftp.zyxel.com/VMG3625-T50B/firmware/ contains the old one.
Best regards,
Petr Flegr
Best regards,
Petr Flegr
Hello @PetrFAccording to the support page you link to at https://www.zyxel.com/support/DNSpooq.shtml , the firmware will be available in June 2021.I hope that this is helpful. Happy Easter.Kind regards,Tony
Tony, thanks for reaction. But where can I get the newer version then the initial one.
V5.50(ABPM.1)C0
V5.50(ABPM.2)C0
V5.50(ABPM.3)C0
V5.50(ABPM.4)C0
V5.50(ABPM.5)C00 -
Hi Petr,
I think you might need to contact with your local ISP to required.
Hope the information is helpful.
cheers,0 -
Solved, I've contacted Zyxel support.
thanks Nikki
thanks Tony1 -
Be aware from googling for any firmware especially this firmware version "V550ABPM2D0.bin" , it mess up any Zyxel 3625 and you will not be able to login with the router default login & password.
do you have the firmware? could you please upload them all maybe? i have the vmg3625-t50b and original zyxel firmware cant be uploaded to it0
- 213 Nebula Ideas
- 550 USG FLEX H Series
- 341 Security Ideas
- 295 Service & License
- 469 News and Release
