Fast roaming doesn't work with DPPSK
Hi @dempie
After looking into your settings, we setup a same environment and the case can be reproduced.
We’re investigating the root cause and will fix it asap.
Before solution released, pleased disable 11r as a workaround.
Sorry for causing inconvenience and thanks for concerning the issue.
Regards,
Bella
Hi @dempie
Thank you for reporting the observation.
Please enable the Zyxel support at Help > Support request > Invite Zyxel support as administrator, and provide the Org and Site name for us to check.
We’ll check the conditions and update you once the information confirmed.
Regards,
Bella
Hi @dempie
Regards,
Bella
Zyxel_Bella said:
Hi @dempie
Regards,
Bella
thank you for looking into that case. Good to know support is very fast.
Best Regards,
dempie0 -
Hi @Zyxel_Bella,
does new version V6.30(ABTF.0) of AP firmware solve fast roaming problem?
Thanks.
Regards, dempie0 -
Hi @dempie
Sorry for the late reply, the fix of DPPSK vlan problem with fast roaming not yet been in time to be released in the version V6.30P0C0.
https://community.zyxel.com/en/discussion/12462
But good news is the solution has been found, we can help you upgrade to date firmware once you provide the schedule for us to apply.
Please enable the Zyxel support at Help > Support request > Invite Zyxel support as administrator, and provide the Org and Site name.
It’s fine if you want to wait the official release included the solution.
Feel free to let us know. Thank you!
Regards,
Bella
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
