NSA320 RAID 0 JBOD how to restore files from HDD
deocPL
Hi there, I look for help. I didn't see answer, so I put question here.
I've got 2 WD disk - They are in GREAT condition as I think after 12 years
NAS was mostly turn off, and was only for old pictures storage.
Last day, I can't see the FOLDERS when I connect via NAS starter utilitty.
I get them out of NAS, and try to recover data.
In admin mode I see like this.
HDSentinel find 1 bad block on HDD.
I put them into USB docking station. I sign which one was in which bay in NAS
How I can restore data from disk? I try to use Hetman RAID Recovery, but I'm not so sure what to set.
In automatic mode, he see 3 options:
1. RAID 1 MIRROR - BUT SIZE SHOWS 1,82T - of course I have RAID 0
2. RAID 0 (Stripe) -
3. JBOD
Both STATUS is DAMAGED
If I choose JBOD , and deep scan (selecting EXT2 and XFS manually as a file system It finds only 2000 files, and as I see only 1 HDD led blinking.
I can install any linux distro for viewing and copy data from discs?
3. JBOD
-- Physical Disk Information - Disk: #5: WDC WD20EARS-00S8B1 --
Hard Disk Summary
Hard Disk Number . . . . . . . . . . . . . . . . : 5
Interface . . . . . . . . . . . . . . . . . . . : USB Attached SCSI (UASP) SAT Standard USB/ATA
Vendor Information . . . . . . . . . . . . . . . : VID: 152D, PID: 8561
Disk Controller . . . . . . . . . . . . . . . . : AMD USB 3.10 eXtensible Host Controller - 1.10 (Microsoft) (USB 3.0) [VEN: 1022, DEV: 149C] Version: 10.0.19041.1320, 10-13-2021
Hard Disk Model ID . . . . . . . . . . . . . . . : WDC WD20EARS-00S8B1
Firmware Revision . . . . . . . . . . . . . . . : 80.00A80
Hard Disk Serial Number . . . . . . . . . . . . : WD-WCAVY5973974
Total Size . . . . . . . . . . . . . . . . . . . : 1907726 MB
Power State . . . . . . . . . . . . . . . . . . : Active
Current Temperature . . . . . . . . . . . . . . : 46 °C (Overheat)
Maximum Temperature (Ever Measured) . . . . . . : 46 °C, 10.01.2022 04:15:07
Minimum Temperature (Ever Measured) . . . . . . : 46 °C, 10.01.2022 04:15:07
Maximum Temperature (During Entire Lifespan) . . : 56 °C
Power On Time . . . . . . . . . . . . . . . . . : 683 days, 12 hours
Estimated Remaining Lifetime . . . . . . . . . . : more than 1000 days
Health . . . . . . . . . . . . . . . . . . . . . : #################### 100 % (Excellent)
Performance . . . . . . . . . . . . . . . . . . : #################### 100 % (Excellent)
The hard disk status is PERFECT. Problematic or weak sectors were not found and there are no spin up or data transfer errors.
No actions needed.
ATA Information
Hard Disk Cylinders . . . . . . . . . . . . . . : 3876021
Hard Disk Heads . . . . . . . . . . . . . . . . : 16
Hard Disk Sectors . . . . . . . . . . . . . . . : 63
ATA Revision . . . . . . . . . . . . . . . . . . : ATA8-ACS
Transport Version . . . . . . . . . . . . . . . : SATA Rev 2.6
Total Sectors . . . . . . . . . . . . . . . . . : 488378646
Bytes Per Sector . . . . . . . . . . . . . . . . : 4096 [Advanced Format]
Multiple Sectors . . . . . . . . . . . . . . . . : 16
Error Correction Bytes . . . . . . . . . . . . . : 50
Unformatted Capacity . . . . . . . . . . . . . . : 1907729 MB
Maximum PIO Mode . . . . . . . . . . . . . . . . : 4
Maximum Multiword DMA Mode . . . . . . . . . . . : 2
Maximum UDMA Mode . . . . . . . . . . . . . . . : 300 MB/s (6)
Active UDMA Mode . . . . . . . . . . . . . . . . : 300 MB/s (6)
Minimum Multiword DMA Transfer Time . . . . . . : 120 ns
Recommended Multiword DMA Transfer Time . . . . : 120 ns
Minimum PIO Transfer Time Without IORDY . . . . : 120 ns
Minimum PIO Transfer Time With IORDY . . . . . . : 120 ns
ATA Control Byte . . . . . . . . . . . . . . . . : Valid
ATA Checksum Value . . . . . . . . . . . . . . . : Valid
S.M.A.R.T. Details
Off-line Data Collection Status . . . . . . . . : Suspended By Interrupting Command From Host
Self Test Execution Status . . . . . . . . . . . : Successfully Completed
Total Time To Complete Off-line Data Collection : 40260 seconds
Execute Off-line Immediate . . . . . . . . . . . : Supported
Abort/restart Off-line By Host . . . . . . . . . : Not supported
Off-line Read Scanning . . . . . . . . . . . . . : Supported
Short Self-test . . . . . . . . . . . . . . . . : Supported
Extended Self-test . . . . . . . . . . . . . . . : Supported
Conveyance Self-test . . . . . . . . . . . . . . : Supported
Selective Self-Test . . . . . . . . . . . . . . : Supported
Save Data Before/After Power Saving Mode . . . . : Supported
Enable/Disable Attribute Autosave . . . . . . . : Supported
Error Logging Capability . . . . . . . . . . . . : Supported
Short Self-test Estimated Time . . . . . . . . . : 2 minutes
Extended Self-test Estimated Time . . . . . . . : 459 minutes
Conveyance Self-test Estimated Time . . . . . . : 5 minutes
Last Short Self-test Result . . . . . . . . . . : Never Started
Last Short Self-test Date . . . . . . . . . . . : Never Started
Last Extended Self-test Result . . . . . . . . . : Never Started
Last Extended Self-test Date . . . . . . . . . . : Never Started
Last Conveyance Self-test Result . . . . . . . . : Never Started
Last Conveyance Self-test Date . . . . . . . . . : Never Started
Disk Information
Disk Family . . . . . . . . . . . . . . . . . . : Caviar Green
Form Factor . . . . . . . . . . . . . . . . . . : 3.5"
Capacity . . . . . . . . . . . . . . . . . . . . : 2 TB (2 x 1 000 000 000 000 bytes)
Number Of Disks . . . . . . . . . . . . . . . . : 4
Number Of Heads . . . . . . . . . . . . . . . . : 8
Disk Interface . . . . . . . . . . . . . . . . . : Serial-ATA/300
Buffer-Host Max. Rate . . . . . . . . . . . . . : 300 MB/seconds
Buffer Size . . . . . . . . . . . . . . . . . . : 65536 KB
Drive Ready Time (Typical) . . . . . . . . . . . : ? seconds
Average Seek Time . . . . . . . . . . . . . . . : ? ms
Track To Track Seek Time . . . . . . . . . . . . : ? ms
Full Stroke Seek Time . . . . . . . . . . . . . : ? ms
Width . . . . . . . . . . . . . . . . . . . . . : 101,6 mm (4,0 inch)
Depth . . . . . . . . . . . . . . . . . . . . . : 147,0 mm (5,8 inch)
Height . . . . . . . . . . . . . . . . . . . . . : 25,4 mm (1,0 inch)
Weight . . . . . . . . . . . . . . . . . . . . . : 640 grams (1,4 pounds)
Acoustic (Idle) . . . . . . . . . . . . . . . . : 2,4 Bel
Acoustic (Min Performance And Volume) . . . . . : 2,5 Bel
Acoustic (Max Performance And Volume) . . . . . : 2,9 Bel
Required Power For Spinup . . . . . . . . . . . : 1 759 mA
Power Required (Seek) . . . . . . . . . . . . . : 6,0 W
Power Required (Idle) . . . . . . . . . . . . . : 3,7 W
Power Required (Standby) . . . . . . . . . . . . : 0,8 W
Manufacturer . . . . . . . . . . . . . . . . . . : Western Digital Corporation
Manufacturer Website . . . . . . . . . . . . . . : http://www.westerndigital.com/en/products
S.M.A.R.T.
No. Attribute Thre.. Value Worst Data Status Flags
1 Raw Read Error Rate 51 200 197 000000000007 OK Self Preserving, Error-Rate, Performance, Statistica..
3 Spin Up Time 21 166 148 0000000021EB OK Self Preserving, Performance, Statistical, Critical
4 Start/Stop Count 0 95 95 000000001511 OK (Always passing) Self Preserving, Event Count, Statistical
5 Reallocated Sectors Co.. 140 200 200 000000000000 OK Self Preserving, Event Count, Statistical, Critical
7 Seek Error Rate 0 200 200 000000000000 OK (Always passing) Self Preserving, Error-Rate, Performance, Statistical
9 Power On Time Count 0 78 78 000000004014 OK (Always passing) Self Preserving, Event Count, Statistical
10 Spin Retry Count 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
11 Drive Calibration Retr.. 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
12 Drive Power Cycle Count 0 97 97 000000000C81 OK (Always passing) Self Preserving, Event Count, Statistical
192 Power off Retract Cycl.. 0 196 196 000000000C58 OK (Always passing) Self Preserving, Event Count, Statistical
193 Load/Unload Cycle Count 0 1 1 0000000A61A2 OK (Always passing) Self Preserving, Event Count, Statistical
194 Disk Temperature 0 106 96 00000000002E OK (Always passing) Self Preserving, Statistical
196 Reallocation Event Count 0 200 200 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
197 Current Pending Sector.. 0 200 198 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
198 Off-Line Uncorrectable.. 0 200 197 000000000000 OK (Always passing) Self Preserving, Event Count
199 Ultra ATA CRC Error Co.. 0 200 200 00000000000B OK (Always passing) Self Preserving, Event Count, Statistical
200 Write Error Rate 0 200 199 000000000000 OK (Always passing) Error-Rate
-- Physical Disk Information - Disk: #6: WDC WD20EARS-00S8B1 --
Hard Disk Summary
Hard Disk Number . . . . . . . . . . . . . . . . : 6
Disk Controller . . . . . . . . . . . . . . . . : Urządzenie pamięci masowej SCSI (UAS) podłączane do portu USB (IDE) Version: 10.0.19041.1023, 6-21-2006
Disk Location . . . . . . . . . . . . . . . . . : Bus Number 0, Target Id 0, LUN 1
Hard Disk Serial Number . . . . . . . . . . . . : WD-WCAVY5957993
Maximum Temperature (During Entire Lifespan) . . : 60 °C
Power On Time . . . . . . . . . . . . . . . . . : 663 days, 10 hours
Health . . . . . . . . . . . . . . . . . . . . . : ###################- 99 % (Excellent)
There is 1 weak sector found on the disk surface. It may be remapped any time in the later use of the disk.
More information: https://www.hdsentinel.com/hard_disk_case_weak_sectors.php
At this point, warranty replacement of the disk is not yet possible, only if the health drops further.
It is recommended to examine the log of the disk regularly. All new problems found will be logged there.
No actions needed.
S.M.A.R.T. Details
Total Time To Complete Off-line Data Collection : 41100 seconds
Extended Self-test Estimated Time . . . . . . . : 468 minutes
Disk Information
S.M.A.R.T.
1 Raw Read Error Rate 51 200 200 000000000000 OK Self Preserving, Error-Rate, Performance, Statistica..
3 Spin Up Time 21 161 143 0000000022CC OK Self Preserving, Performance, Statistical, Critical
4 Start/Stop Count 0 95 95 00000000175E OK (Always passing) Self Preserving, Event Count, Statistical
9 Power On Time Count 0 79 79 000000003E32 OK (Always passing) Self Preserving, Event Count, Statistical
12 Drive Power Cycle Count 0 99 99 0000000006CB OK (Always passing) Self Preserving, Event Count, Statistical
192 Power off Retract Cycl.. 0 198 198 0000000006AC OK (Always passing) Self Preserving, Event Count, Statistical
193 Load/Unload Cycle Count 0 1 1 0000000B31A4 OK (Always passing) Self Preserving, Event Count, Statistical
194 Disk Temperature 0 106 92 00000000002E OK (Always passing) Self Preserving, Statistical
197 Current Pending Sector.. 0 200 200 000000000001 OK (Always passing) Self Preserving, Event Count, Statistical
198 Off-Line Uncorrectable.. 0 200 200 000000000000 OK (Always passing) Self Preserving, Event Count
199 Ultra ATA CRC Error Co.. 0 200 200 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
200 Write Error Rate 0 200 200 000000000000 OK (Always passing) Error-Rate
Best Answers
According to this bootlog the NAS uses ext3, not xfs.It's hard to interpret the screenshots of Hetman Raid recovery. When it 'understands' the disks, it should assemble the array right away, or give a clear error message. Both disks have a raid header, describing the raid array, so assuming only one disk might have a small error in that header (HDsentinel) the tool should be able to tell which kind of raid array it is.How did you connect the disks? When using an USB to Sata converter that could be a problem. Some do sector size conversions, rendering the partition table incompatible. Maybe Hetman can tell something about the logical sector size? It should be 512 bytes. The physical sector size is something different, that could be both 4k or 512 bytes.I'd definitely try a Linux system.0
The soluntion WAS BIULD IN into adminstrator panel !
The only thing I have to do is...
Scan VOLUME
After first scan I get errors, and info about run it again.
Second scan gives me an solution, and fix error:
LOG FROM auto scan:Phase 1 - find and verify superblock...Phase 2 - using internal log- zero log...ALERT: The filesystem has valuable metadata changes in a log which is beingdestroyed because the -L option was used.- scan filesystem freespace and inode maps...agi_freecount 810 counted 795 in ag 0agi unlinked bucket 20 is 34644 in ag 0 (inode=34644)agi unlinked bucket 54 is 886 in ag 0 (inode=886)agi unlinked bucket 60 is 1793264956 in ag 0 (inode=1793264956)sb_ifree 810 counted 795sb_fdblocks 89959 counted 89958- found root inode chunkPhase 3 - for each AG...- scan and clear agi unlinked lists...- process known inodes and perform inode discovery...- agno = 04001d350: Badness in key lookup (length)bp=(bno 416 len 16384 bytes) key=(bno 416 len 8192 bytes)bad stale count in block 8388610 of directory inode 1131imap claims a free inode 311427315 is in use correcting imap and clearing inodecleared inode 311427315imap claims a free inode 311427317 is in use correcting imap and clearing inodecleared inode 311427317correcting imapcorrecting imapcorrecting imapdata fork in ino 1793264964 claims free block 770637911data fork in ino 1793264966 claims free block 770637912data fork in ino 1793264970 claims free block 770645443data fork in ino 1793264972 claims free block 770645444data fork in ino 1793264979 claims free block 808863535- agno = 1- agno = 2- agno = 3- process newly discovered inodes...Phase 4 - check for duplicate blocks...- setting up duplicate extent list...- check for inodes claiming duplicate blocks...- agno = 0entry G0232909.JPG at block 1 offset 1040 in directory inode 58669888 references free inode 311427315clearing inode number in entry at offset 1040...entry G0232909.JPG.cacheinfo at block 1 offset 1136 in directory inode 58670094 references free inode 311427317clearing inode number in entry at offset 1136...- agno = 1- agno = 2- agno = 3Phase 5 - rebuild AG headers and trees...- reset superblock...Phase 6 - check inode connectivity...- resetting contents of realtime bitmap and summary inodes- traversing filesystem ...rebuilding directory inode 1131bad hash table for directory inode 58669888 (no data entry): rebuildingrebuilding directory inode 58669888bad hash table for directory inode 58670094 (no data entry): rebuildingrebuilding directory inode 58670094- traversal finished ...- moving disconnected inodes to lost+found ...disconnected inode 886 moving to lost+founddisconnected inode 34644 moving to lost+founddisconnected inode 611966605 moving to lost+founddisconnected inode 611966606 moving to lost+founddisconnected inode 611966607 moving to lost+founddisconnected inode 1793264956 moving to lost+foundPhase 7 - verify and correct link counts...Note - quota info will be regenerated on next quota mount.done0
Scan VOLUME
LOG FROM auto scan:Phase 1 - find and verify superblock...Phase 2 - using internal log- zero log...ALERT: The filesystem has valuable metadata changes in a log which is beingdestroyed because the -L option was used.- scan filesystem freespace and inode maps...agi_freecount 810 counted 795 in ag 0agi unlinked bucket 20 is 34644 in ag 0 (inode=34644)agi unlinked bucket 54 is 886 in ag 0 (inode=886)agi unlinked bucket 60 is 1793264956 in ag 0 (inode=1793264956)sb_ifree 810 counted 795sb_fdblocks 89959 counted 89958- found root inode chunkPhase 3 - for each AG...- scan and clear agi unlinked lists...- process known inodes and perform inode discovery...- agno = 04001d350: Badness in key lookup (length)bp=(bno 416 len 16384 bytes) key=(bno 416 len 8192 bytes)bad stale count in block 8388610 of directory inode 1131imap claims a free inode 311427315 is in use correcting imap and clearing inodecleared inode 311427315imap claims a free inode 311427317 is in use correcting imap and clearing inodecleared inode 311427317correcting imapcorrecting imapcorrecting imapdata fork in ino 1793264964 claims free block 770637911data fork in ino 1793264966 claims free block 770637912data fork in ino 1793264970 claims free block 770645443data fork in ino 1793264972 claims free block 770645444data fork in ino 1793264979 claims free block 808863535- agno = 1- agno = 2- agno = 3- process newly discovered inodes...Phase 4 - check for duplicate blocks...- setting up duplicate extent list...- check for inodes claiming duplicate blocks...- agno = 0entry G0232909.JPG at block 1 offset 1040 in directory inode 58669888 references free inode 311427315clearing inode number in entry at offset 1040...entry G0232909.JPG.cacheinfo at block 1 offset 1136 in directory inode 58670094 references free inode 311427317clearing inode number in entry at offset 1136...- agno = 1- agno = 2- agno = 3Phase 5 - rebuild AG headers and trees...- reset superblock...Phase 6 - check inode connectivity...- resetting contents of realtime bitmap and summary inodes- traversing filesystem ...rebuilding directory inode 1131bad hash table for directory inode 58669888 (no data entry): rebuildingrebuilding directory inode 58669888bad hash table for directory inode 58670094 (no data entry): rebuildingrebuilding directory inode 58670094- traversal finished ...- moving disconnected inodes to lost+found ...disconnected inode 886 moving to lost+founddisconnected inode 34644 moving to lost+founddisconnected inode 611966605 moving to lost+founddisconnected inode 611966606 moving to lost+founddisconnected inode 611966607 moving to lost+founddisconnected inode 1793264956 moving to lost+foundPhase 7 - verify and correct link counts...Note - quota info will be regenerated on next quota mount.done0 -
deocPL said:- moving disconnected inodes to lost+found ...disconnected inode 886 moving to lost+founddisconnected inode 34644 moving to lost+founddisconnected inode 611966605 moving to lost+founddisconnected inode 611966606 moving to lost+founddisconnected inode 611966607 moving to lost+founddisconnected inode 1793264956 moving to lost+foundGlad you sorted it. The repair procedure has moved some files or directories to lost+found, this are files or directories which got 'orphaned' because the containing directory was corrupted.If you have shell access, you can find them in /i-data/md0/lost+found/. This directory is for obvious reasons only accessible by user 'root'.
- 588 USG FLEX H Series
- 477 News and Release
