latest firmware for VMG3625-T50B
tlanik
in Home Router
hello, where can I get latest firmware for VMG3625-T50B? I'm looking for V5.50(ABPM.6)C0 planned for release in June 2021, mentioned in https://www.zyxel.com/support/DNSpooq.shtml
thank you, Tomas
Hi Tomas
You might need to check with your ISP for the FW upgrade.
Normally, FW versions were managed by the ISP.0 -
Hi, I have bought the router myself, it is not maintained by ISP. Has Zyxel this firmware available for download and install by end user?0
Is this some joke? Where is the firmware??0
Hi all,
The only one I can find is at https://spdestek.zyxel.com.tr/hc/tr/articles/4408476854929-VMG3625-T50B-T%C3%BCrknet-V550ABPM5F1- BUT only for use on the Turknet campaign routers, sold in Turkey.
No show otherwise.
Kind regards,
Tony0 -
finally, I have raised support ticket on https://support.zyxel.eu/hc/en-us/requests/new, immediatelly got response with updated firmware (https://www.dropbox.com/s/y7ss2w1qkto6rgv/V550ABPM6C0.zip?dl=1), everything works and day is sunny..2
tlanik said:finally, I have raised support ticket on https://support.zyxel.eu/hc/en-us/requests/new, immediatelly got response with updated firmware (https://www.dropbox.com/s/y7ss2w1qkto6rgv/V550ABPM6C0.zip?dl=1), everything works and day is sunny..
@@tlanik hi bro , can you tell me if the QoS has been changed like this for you too please ? https://community.zyxel.com/en/discussion/12811/qos-upload-download-vanished-can-i-get-them-back/p1?new=10 -
What is the password of this version of firmware after using it and factory reset my router can't login using the labeled password on my router or admin/1234 do you know it ? maybe it's yours ? my WIFI SSID has changed to Zyxel_8541 too and I can't connect to it
how make new firmware-1
I've flashed the firmware linked to by tlanik (from V5.50(ABPM.0)C0 to V5.50(ABPM.6)C0) without resetting to defaults with no issue.
The default password included in the passwd file with the firmware is admin/1234, so that's probably what it is going to be if you reset to defaults, otherwise your old password stays.
Here's sha256hash of the firmware file in case that's useful to someone
d5ff9b24987057a546371f9556b353ae0506646c370fd539773a62d37d2ba2df V550ABPM6C0.bin
password please
-1
- 441 Beta Program
- 293 Service & License
