IPSec VPN Profile for IOS with FW 5.2
Hi
I test the new native IPSec v2 connection to an Ipad with FW 5.2 (great work, BTW 👍)
How can I get the config to my Ipda? At the end of the "quick setup" I can export the config, but can I also get it from the webinterface when I log in with the VPN user? (self-service)
This was possible with the old L2TP VPN over the "Configuration Provisioning" option.
Currently I don't see an option for this?
Mario
Hi @Mario
VPN configuration provision in login portal page only support for IOS, since iPadOS is no belonging to iOS, so the session page will not display the download button to you.
In 5.20 version, wizard will generates different platform configuration for Windows/IOS/MacOS/Android VPN client. You can download them when creating VPN rule by wizard.
Also if user could download all of platform VPN configuration after logging into system, then will much friendly. So I reported is as idea as requirement.0
It looks you have to add IKEv2 configuration manually....since iPadOS is neither iOS or macOS.
You can export the certificate from firewall, and open it by Safari.
And then go to create IKEv2 VPN rule on your iPad after trusting the certificate.
Hi @CHSThanks for your reply. At 5.2 you have the optoin to export "RemoteAccess_iOS_301.mobileconfig" at the end of the quick setup (small icon on the left side) .You can import this file on IOS and just enter username and password, then the vpn works.I like to have an option to allow the users to log on on the firewall directly on IOS / Android and get the "RemoteAccess_iOS_301.mobileconfig" or "RemoteAccess_ANDROID_270.sswan" for IOS or Android.
Hi @Zyxel_StanleyThis is what I expect, but on my Ipad 6. gen with 15.2.1 with safari I don't have the option to download the profile:
Is this a bug?
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
