Site to site IPSec VPN: VLAN5 <-> LAN2 interface
I’m trying to set up a tunnel between a VLAN on 1 site and a regular LAN interface on the other site. The tunnel seems to work fine, but I cannot make any connection to the devices.
I have tried site to site and vti, both seem to connect, but cannot ping. Tunnel interface between 2 LAN interfaces is no problem, but I need VLAN <-> LAN2.
VPN_TEL_LOCAL Left: Subnet: 192.168.5.0
VPN_TEL_REMOTE Left: Subnet: 192.168.10.0
VPN_TEL_LOCAL Right: Subnet: 192.168.10.0
VPN_TEL_REMOTE Right: Subnet 192.168.5.0
Still no response on both sides. Any help?
You want site to site with at least one end nailed-up the status will show the tunnel is up
If you have setup the Local and remote policy right with a zone for the site to site then you might need a routing rule.
Incoming Interface
member LAN/ge
destination the remote subnet
next hop
type VPN Tunnel
tunnel your zone for the site to site
Then a firewall for LAN to zone site to site
What's about your Security Policy ? Have you allowed the traffic ?
Also,Please check there is no "Source Network Address Translation" applied.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
