NAS326, MetaRepository not Working Correctly
ceyhun41
Hello, I am a Nas326 user. While trying to update from outdated apps, I discovered an alternative repo to the expired Zyxel repos. As you all know, I am using this repo link;
I downloaded the http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/web_prefix file to the /i-data/11dbf589/admin/zy-pkgs file directory for installation. When I refresh App Center, MetaRepository is listed. But my other installed apps are not showing up. I disabled it then enabled it again and the result didn't change. When I ping zyxel.diskstation.eu, I get a successful response.
What is the problem? Can you help me?
List Fail :
Pinging zyxel.diskstation.eu result:
/i-data/sysvol/admin/zy-pkgs/MetaRepository directory:
#NAS_Jan_2022
I think the answer can be found in the 2 logfiles. But at the moment the ftp server on ftp2.zyxel.com is down for me. That could be the problem, you can try to put a # before that line in the webinterface, and retry.
How did you manage to access this /i-data/sysvol/admin/zy-pkgs/MetaRepository directory? Which software you are using?
Ignore this question, I found out. Best way is via WinSCP.
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
