GS1910-48 firmware. Where can I find it?
CAN
CAN Posts: 5  Freshman Member
First Anniversary
edited August 2022 in Switch
I've been searching everywhere on this site, but cannot find the firmware for GS1910-48. Could someone provide me with a download link?
Best Answers
  • Zyxel_Adam
    Zyxel_Adam Posts: 430  Zyxel Employee
    Zyxel Certified Network Administrator - Nebula 25 Answers First Comment Friend Collector
    Hi @CAN,
    Welcome to Zyxel Community!
    Since GS1910-48 is already EOL, please click here to search GS1910-48 switch and download the latest firmware.
    Don't hesitate to inquire us if there is any question.
    Adam
  • Zyxel_Adam
    Hi @CAN,
    I just send the firmware V1.00(AAAZ.2) via private message to you, please check your mail inbox.
    Adam
  • Zyxel_Adam
    Hi @CAN,
    Adam
  • CAN
    First Anniversary
    edited January 2022
    Thank you for the quick response. Alas I'm unable to perform the upgrade. In order to follow the correct upgrade flow I need firmware version 1.00(AAAZ.2) before I can make an attempt to upgrade to the latest version.
    Could you provide me the link to version 1.00(AAAZ.2)?
  • Zyxel_Adam
    Hi @CAN,
    Adam
  • CAN
    First Anniversary
    Thank you very much for the quick resolution.
  • Babs
    Babs Posts: 1
    I have the same issue, my switch is still on Software version V1.00(AAAZ.0) and I need the firmwares to do the upgrade path, which looking at the comments means I need V1.00(AAAZ.2) before I can move to V2.00(AAAZ.0)C0, can anyone help with where to get the V1.00(AAAZ.2) firmware please?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,529  Zyxel Employee
    Hi @Babs,
    Welcome to Zyxel community!
    The attachment is the V1.00(AAAZ.2) firmware.
    If you need other help, please feel free to create a post, our agent will help you.
    Zyxel Melen
  •  my switch is still on Software version V1.00(AAAZ.2 can anyone help with where to get the V2.00(AAAZ.0)C0, firmware please?
  • Zyxel_Melen
    Hi @Teaboon,
    Here's the V2.00(AAAZ.0)C0 firmware.
    Zyxel Melen
  • sileclercq
    sileclercq Posts: 6  Freshman Member
    Hi, I also have a GS1910-48 : is there a newer firmware than the one i have ? Where can i find it please ? Thanks
    Software
    Software Version
    V2.00(AAAZ.0)C0
    Software Date
    2014-06-25T06:36:00+02:00
    Code Revision
    258cf9a62e22
  • sileclercq
    Hi, Is there a newer version of the firmware for my GS1910-48 device ? Thanks
    Software
    Software Version
    V2.00(AAAZ.0)C0
    Software Date
    Code Revision
    258cf9a62e22
