How to add a single ext4 formatted HD into an nas542 without reformatting?
Hi all!
I have 4 drives that are ext 4 formatted and have some files on them. I have several nas542 systems and in the past I have used empty disks that I formatted and then filled over time.
This time I would like to use the existing ext 4 formatted disks as they are, i.e. without formatting them first. Is it possible to just mount them? In the web interface I see them under Storage Manager -> Internal -> Hard Disk but I can't access them. The way I understand it by creating a volume I would format them
Is it possible to avoid formatting the disks and use them as they are? I have ssh access set up and have used the metarepository tools in the past. I don't care whether they show up in the Gui as long as I can use them via smb.
Thanks for your help!
  • Mijzelf
    Mijzelf Posts: 2,395
    250 Answers 1000 Comments Friend Collector Fifth Anniversary
    It can be done temporarily. Find the devicename of the partition with
    cat /proc/partitions
    Then mount it:
    mkdir /mnt/mountpoint
    mount /dev/<devicename> /mnt/mountpoint
    It is possible that the firmware jumps in and moves the mount. In that case it will show up in the gui.
    If not, you'll have to edit /etc/samba/smb.conf to add the disk as a share, and, and restart samba:
    /etc/init.d/samba.sh restart
    This won't survive a reboot.
  • Thanks a lot, I'll try this!
