Cant access my NAS326
According to the prompt ( ~# ) the current directory is the home directory of root. Which is not /i-data/sysvol/.So executels /i-data/sysvol/lost+found/0
Here is my sequence of commands...No result for me0
In that case the directory is not lost by a filesystem corruption, and found by filesystemcheck. There is a possibility that filesystemcheck has not been run, yet. So run 'Volume check' in the webinterface, and recheck lost+found after that.Have a look at the output of volume check, I don't know if it will succeed.0
-1
Now I got stuck...Googled and search documents without finding how to do a Volume check0
Right. I couldn't find it either. Apparently the function is removed in the NAS series. I'm sure my NSA325 had it.The filesystem cannot be repaired while it is mounted, but at least you can check if there are errors:sue2fsck -nf /dev/md2It will spawn a warning that the filesystem is mounted, that is OK. Try to not access the shares while the check is running.
Here is the result of that scan.
According to that result there might be 13 files lost (including directories) with a maximum total size of 68kB. If you think that could be your files, you can follow the directions here to perform a filesystem repair. Unfortunately the forum software has b0rked up my layout, so you'll have to remove the html code between the commands.But I doubt that are your files. Could it be you moved them, somehow? If you know a filename which should absolutely be in that lost directory, you can find it withfind /i-data/sysvol/ | grep -i "filename"
Tried to find some different files with out any luck.Is there a command to find a folder, because I am 100% sure of foldernames.0
The same command should be able to find foldernames. If you just runfind /i-data/sysvol/it shows all files, with the folder(s) they are contained by, and grep is a tool to filter only the lines containing a certain value.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 457 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
