Reboot USG110 + startup log
Hi, today USG110 (FW V4.65(AAPH.1)ITS-WK32) randomly restart, USB disk for log files not functioning (i must re-unplug flashdisk). Thats not my question, so, i see on log :
exception for sparklabs.com (log now is empty, i forget exception more info)
and alot of information
System [SSI] Create the default trusted certificate's symbolic link: 681XXX -> abd256ed695df59XXX... What is this ? Is both correct and safe ?
Best Answers
Hi @kyssling,
Thank your information.In order to decrypt SSL(TLS) connection between Client and External Server when enable SSL Inspection.Firewall will store a lot of Certificate.Like every OS have Certificate Center.All behavoir are nessarary and normal.Please Ignore that. Thank you
Kevin0 -
Hi @kyssling ,
Yes, Sparklabs is our Cooperative manufacturers.
So you would find the domain in exception list.
Thank you.
Kevin0 -
ZyWALL keeps some logs before it reboots.If the device reboots abnormally, you may download diag-info to check if there is any core file generated after device crashed.If yes, it means device crashed. Please forward this issue to ITS systemBut if there is no such core file, you may check if last logs exist on the USG.You can use this CLI command to show logs:Router> show logging last-boot entries0
Hi @kyssling,
Could you kindly share the diag-info in Private Messages?
And Does the message still pop-up?
Kevin0 -
Hello, I sent the diagnostic data via PM, after yesterday's upload of the new FirmWare V4.70 (AAPH.0) ITS-WK46 router restarted and following records appeared again: Info - SSL Inspection - Add Entry of exclude list: sparklabs.comZyxel_Kevin said:Hi @kyssling,
Kevin
Info - System - SSI Create the user trusted certificate's symbolic link ... Vaclav
Kevin
you mean, including an exception on sparklabs.com ...
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
