NAS326 - Transmission
ak_simoN
ak_simoN Posts: 3
edited February 2022 in Personal Cloud Storage
Hello, I have a problem with Transmission. I have version 2.84zypkg002.
Is it possible to have newer version?
I want to set a password but i can't open, edit or copy transmission settings file even if Transmission is disabled
  • Dexter
    Dexter Posts: 108
    Could you share the screenshot of which steps do you stock on it?
  • Mijzelf
    Mijzelf Posts: 2,395
    250 Answers 1000 Comments Friend Collector Fifth Anniversary
    You need to login as root to have permission to edit that file. Make sure transmission is not running.
  • ak_simoN
    ak_simoN Posts: 3
    I login as a root and I can change settings file but it looks like I have two folders with Transmission config files. I will change both of them but how to set up password to log in to transmission WebGUI from WAN
