How to configure Vlan Trunk - Gs1910
KleinStreisend
Good afternoon, could you tell me how to configure the trunk port for vlan on the zyxel gs1910 switch. I have 2 vlans 100 and 200.
It is necessary to connect 2 switches so that vlan traffic passes between them.
Also, these ports are aggregated via LACP. Actually, I need to make them a trunk port.
On cisco, this is done through the "switchport mode trunk" command.
Hi @KleinStreisend,
Welcome to Zyxel community!
Looks like you want lacp ports could transmit VLAN 100 & 200, right?
If yes, you just need to set "1,100,200" in Allowed VLANs on lacp ports.
Hope it Helps.
Zyxel Melen1
Hi @KleinStreisend,
Hope it Helps.
Zyxel Melen1 -
@Zyxel_Melen
thank you very much, yes it is working perfectly.
On the cisco side work with -
switchport nonegotiate0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
- 106 Security Highlight
