Where is the support/download section for AX7501-B0
monsieur_cedric
Having issues with my new AX7501-B0 (10g fiber router): short Lan drops, long Wifi drops (with several devices, even facing the routeur). I would like to know if there is a new firmware to fix these issues or if my routeur is faulty.
Thanks in advance.
Thanks in advance.
For the new firmware, it may depends on your supplier.
If your AX7501-B0 comes from ISP, you may need to check with your ISP for new firmware version.1 -
Hello @monsieur_cedricThere is some advice at https://support.zyxel.eu/hc/en-us/articles/360019108619-Zyxel-security-advisory-for-DNSpooq which follows what @SEJ said.There are Downloads and resources also at https://service-provider.zyxel.com/global/en/products/wifi-system/mpro-mesh-wifi-gateways/ax7501-b0Kind regards, Tony
Can You give me a model name of transciver in AX7501-B0 router please?0
The AX7501-B0 router uses a variety of different transceivers, depending on the specific model and configuration. Some common transceivers used in AX7501-B0 routers include the following:• Intel X550-AT2 10GBASE-T Ethernet Converged Network Adapter• Cisco SFP+ 10GBase-SR Transceiver Module• HP X121 1G SFP LC SX Transceiver• Juniper Networks EX-SFP-10GE-USR USR 10000Base-X SFP+ ModuleDepending on the model and configuration of your specific router, it may use one or more of these transceivers.-1
Hi all,
There is now firmware version 5.15(ABPC.1)C0 for AX7501-BO available to download at https://support.zyxel.eu/hc/en-us/articles/360019108619-Zyxel-security-advisory-for-DNSpooq
Kind regards,
Tony0 -
Hi all,
There is now available firmware version
5.17(ABPC.5)C0 available under the Downloads and Resources tab at https://www.zyxel.com/service-provider/emea/en/products/fiber-oltsonts/10g-active-fiber/hgus/ax7501-b-series0
- 439 Beta Program
- 190 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 305 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
