NWA210AX rebooting
System
Admin
Admin
This discussion was created from comments split from: NWA210AX Firmware Available and won't update.
Hi, my NEW NWA210AX continue rebootin trying to upgrade firmware, i can access the admin panel few mintues untill it restart itself, i tried clicker counter to:How to check for available updates. Depending on the device, you will have a different method of checking for available firmware updates. Some ...
Hi @Noradavis,
Sorry for causing your inconvenience, may I know how do you manage your APs ? standalone or through NCC?
If the AP is managed by NCC, please help us to enable the Zyxel support under [Help (bottom-left of the dashboard) > Support Request > Invite Zyxel Support as Administrator > Save], and provide us the name of your Org/Site, so that we can further check your Nebula site settings.
If the device is in standalone mode, please first press the reset button, and see if it can boot up successfully.
Best Regards,Richard0 -
Are you powering the AP via POE? If so plug in the power adapter temporarily.Noradavis said:Hi, my NEW NWA210AX continue rebootin trying to upgrade firmware, i can access the admin panel few mintues untill it restart itself, i tried clicker counter to:How to check for available updates. Depending on the device, you will have a different method of checking for available firmware updates. Some ...0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
