IP table collision
DavidDu1130
DavidDu1130 Posts: 2
edited August 2022 in Switch
Hi supporters,
I have two question:
Firstly, I am facing this too much on coreswitch XGS4600 when checking log 7 2022-03-20T20:42:13+07:00 IN switch: IP table collision : 192.168.x.x
Product Model: XGS4600-32F
ZyNOS F/W Version: V4.70(ABBI.2) | 12/17/2021
Could you tell me what should I do to fix this matter.
Secondly, I want to show algorithm crc32l on my zyxel XGS4600 and change it to crc32u . But I dont know which command that help to show. Could you guys help me to do?
  • Zyxel_Jonas
    Zyxel_Jonas Posts: 289
    5 Answers First Comment Friend Collector Fourth Anniversary
    edited March 2022 Answer ✓
    Hi @DavidDu1130,
    Welcome to Zyxel Community!
    Please use the following command to display which hash you were using, like the figure below.
    XGS4600# show running-config
    Note: "crc32l" is the default hash, so it won't display in the running-config.
    In addition, you may use the "help" command for other hash algorithm options:
    XGS4600(config)# ip iptable hash help<br>
    Hope it helps.
    Jonas
    Jonas,
