ZywallATP100 keeps booting
CharlyBrown
in Security
In the last days the network appeared being slow, despite the router being up to speed. Therefore, rebooted the Zywall. Now, it doesn't startup correctly anymore and cannot be reached.
LEDS:
PWR: constant green
SYS: blinking green (for 2 hours or so)
Ports: all off
LEDS:
PWR: constant green
Ports: all off
Last active FW: 5.00
Looking forward to your guidance. Thx
Tried a hard reset - but that didn't have any effect either. Therefore, have sent it now to the technical service point of Zyxel. Let's see what they say.
I have the same problem!
did you get an answer?
@Davide_CUD - No, not yet. The device is on its way to the manufacturer. Knowing that someone is interested in the outcome, I'll post the result here hopefully next week.
You need to update the firmware, see the following post:
@Mario Thank you for that hint - however, if the Zywall device doesn't startup any more and cannot be reset, then I would not know how to patch the firmware...
Hello @CharlyBrown, @Davide_CUD,
If your device was suffering device hang after reboot, please refer to these article to recover the device.
Thanks!
James.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
