I cannot Ping My public IP outside network
rogerIT
rogerIT Posts: 4
Friend Collector First Anniversary
I need your assistance on this.
After I set up my Zyxel firewall in to nebula cloud, I suddenly unable to ping both of my WAN IP (Public IP)
* Reachable when I am inside the network
* RTO when outside the Network
Thanks Guys and God bless!
  • mMontana
    mMontana Posts: 1,248
    50 Answers 1000 Comments Friend Collector Fourth Anniversary
    Is ICMP allowed by rules?
    Is your device allowed to answer ICMP?
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 558
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 50 Answers 500 Comments
    Hi @rogerIT.
    Greeting Forum, Device has the following hidden default firewall rules:
    "LAN to WAN is allowed, WAN to LAN is blocked".
    Please kindly create the rule allow WAN ICMP.
    Kevin
  • rogerIT
    rogerIT Posts: 4
    Hi @Zyxel_Kevin and @mMontana
    Good Day!
    Can you send me a Screenshot of the settings?
    this is my current setting https://prnt.sc/rHXEYPzNiimI
    thank you
  • Zyxel_Kevin
    Hi @rogerIT,
    Kindly share the Nebula Org/Site in Private messages. I will take it care.
    Kevin
  • mMontana
    I'd change the destination from "any" to "Zywall", if possible.
  • rogerIT
    rogerIT Posts: 4
    edited March 2022
    Hi @mMontana and @Zyxel_Kevin
    It works now!!
    I saw this on internet, this may also help some user
    https://prnt.sc/@Zyxel_Kevin
    Thanks Guys
  • mMontana
    I do not use Nebula, so maybe my suggestion was incorrect.
    Into 4.x firmwares, destination "Zywall" is one of the options, brecause "Any" will automatically exclude the Zyxel devices.
    IDK if in Nebula there's something similar.
    Moreover...
    In the default configuration for the USG devices (4.x and 5.x firmware) there's a specific rule for defining what's allowed from wan to firewall and what's not.
    ICMP/PING is not part of this rule. You can find something similar into your nebula config, then add the PING object to services group for allowing connection to firewall.
    Remember: more rules, more refined control.
    Less rules, faster operations
    Be smart and sometimes optimize (rethink) the rules is a good idea.
  • rogerIT
    rogerIT Posts: 4
    @Zyxel_Kevin
    no offense pls, but I am a bit worry about that.
    Can you explain what are the best thing to do instead
Nebula Tips & Tricks
