How do I connect my NWA210AX to the internet?
Hi @Chevelle
AP needs adapter to power up and uplink cable connect to your router/dhcp server for getting internet if you don’t have PoE switch.
To run AP in standalone mode, pressing reset on AP then AP will broadcast SSID Zyxel-xxxx by default. You can connect to the SSID and just type this URL in your browser http://setup.zyxel and it will lead you to the AP admin page. You have to enter default account: admin, password: 1234 to login local GUI.
Run ZON utility to get the information of AP’s IP address also could change the profile as you wish.
https://community.zyxel.com/en/discussion/12598
Thank you
Regards,
Bella
I have the AP working at this point, very good bandwidth with combined speeds of 4800+ which is good. I was able to 'finally' access the web-based sign in page and found the 'assigned' password at the Nebula general page' I had to read to find this out.0
I have the AP working pretty well at this point. I did finally get into the web-based UI but it required an auto generated password that was at the 'nebula general settings' page? It seems that the instruction page could have been arranged more differently to make things easier to understand. It was very confusing for a first-time user of this particular firmware. I might have started with setting up the nebula page first, then explained that the web-based UI loses most of it's functionality once the nebula page is set up. Should I assume that when the 30-day default un-paid limit for the Nebula interface runs out that the web-based interface will be functional again for setting up the wireless settings? A little confused on this. Thanks for the help so far Bella.
Hi @Chevelle
It’s good to hear you could access and control the AP, thanks for the experience for improvement.
We will strengthen the guidelines to help new users easily setup the wireless network with our product.
Thank you
Regards,
Bella
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
