Firmware upgrade from 4.10 to 4.70 - GS1920-24HP
rickyibiza
Hi all!
I have GS1920-24HP switch which has an old firmware on it, 4.10.
Can i upgrade it to the newest one 4.70?
Many thanks!!
Many thanks!!
Hi @rickyibiza,
If your switch is not GS1920-24HPv2, it's not supported to upgrade to V4.70 frimware.
For GS1920-24HP, you can download the latest firmware V4.50 in our EOL list.
Hope it helps,Adam
Hi @rickyibiza,
Hope it helps,Adam
Thank you!!0
Hello, I have GS1920-48v2 and upgraded to V4.50(AANZ.3) how to upgrade to 4.70(ABMJ.4)C0 for example can't find 4.60 on the site.
Kind Regards,
Stoyan0 -
I can't find the GS1920-24HPv in the linked EOL List, where can i get the 4.50 Firmware from?
Hi Zyxel_Adam,
I clicked the link, but the firmware for GS1920-24HP is NOT listed there!
Donald.
- 588 USG FLEX H Series
- 476 News and Release
