XS1930-12HP SFP+ port goes up and down
I am trying to connect XS1930-12HP to Mikrotik RB5009 using SFP+ via a DAC 10GB cable. I also tried 10GB fiber optic cable and saw the same issue. But the connection goes up and down.
The system log looks like:
<br>
63 2022-04-11T23:15:08Z DE interface: Port 12 link down
64 2022-04-11T23:15:07Z DE interface: Port 12 link up 10G/F
65 2022-04-11T23:15:01Z DE interface: Port 12 link down
66 2022-04-11T23:15:01Z DE interface: Port 12 link up N/A
67 2022-04-11T23:14:58Z DE interface: Port 12 link down
68 2022-04-11T23:14:56Z DE interface: Port 12 link up 10G/F
69 2022-04-11T23:14:52Z DE interface: Port 12 link down
70 2022-04-11T23:14:48Z DE interface: Port 12 link up 10G/F
71 2022-04-11T23:14:48Z DE interface: Port 12 link down
72 2022-04-11T23:14:47Z DE interface: Port 12 link up 10G/F
73 2022-04-11T23:14:34Z DE interface: Port 12 link down
74 2022-04-11T23:14:31Z DE interface: Port 12 link up 10G/F
75 2022-04-11T23:14:20Z DE interface: Port 12 link down
76 2022-04-11T23:14:18Z DE interface: Port 12 link up 10G/F
77 2022-04-11T23:14:18Z DE interface: Port 12 link down
78 2022-04-11T23:14:15Z DE interface: Port 12 link up 10G/F
79 2022-04-11T23:14:00Z DE interface: Port 12 link down
80 2022-04-11T23:13:57Z DE interface: Port 12 link up 10G/F
81 2022-04-11T23:13:51Z DE interface: Port 12 link down
82 2022-04-11T23:13:49Z DE interface: Port 12 link up 10G/F
83 2022-04-11T23:13:45Z DE interface: Port 12 link down
84 2022-04-11T23:13:43Z DE interface: Port 12 link up 10G/F
85 2022-04-11T23:13:27Z DE interface: Port 12 link down
86 2022-04-11T23:13:25Z DE interface: Port 12 link up 10G/F
87 2022-04-11T23:13:23Z DE interface: Port 12 link down
88 2022-04-11T23:13:20Z DE interface: Port 12 link up 10G/F
89 2022-04-11T23:13:16Z DE interface: Port 12 link down
90 2022-04-11T23:13:16Z DE interface: Port 12 link up N/A
91 2022-04-11T23:13:04Z DE interface: Port 12 link down
92 2022-04-11T23:13:02Z DE interface: Port 12 link up 10G/F
<br>
Mikrotik just released 7.3beta34 and solved the problem.
Thanks.Fixed 10GBe full duplex does not work for me. But fixed 1GBe full duplex does solve the issue. I just wonder why. And it is not a desirable solution since the speed is much slower.0
Hi @pw123,
Welcome to Zyxel community!Based on the description, may I know if you had tried changed the media type to "DAC 10G" in the Basic setting > Port setup and verify if the port link up/down issue is resolved?If the problem still exists, may I know if your DAC cable does support DDMI?If yes, access XS1930-12HP via web GUI, go to Management > Maintenance and download the "Tech-support" file. So I could check the transceiver information.Reminder: Please send the tech-support file to me by PM, as there's some private information.If the DAC doesn't support DDMI, may I know if you have a Zyxel 10G transceiver for testing?It will help to verify if the problem is related to incompatibility between the DAC and XS1930.In addition, may I know the specific length of your DAC cable?
JonasJonas,0 -
Hi Jonas,I tried dac10g mode and it does not work.The DAC cable does not have DDMI. The DAC cable is 0.5m.I don't have a Zyxel 10G transceiver. I purchased this DAC cable: https://www.optcore.net/product/dac10g-1m-zyx/ and will test it once I get it.On the other hand, I also tried a optic fiber cable with two 10GB optic SFP+ transceiver, which have DDMI information. It does not work either.I will PM you the support files for my two tests.Thanks for helping.
I just tried Mikrotik XS+DA0001 Direct Attach Cable and had no luck. xs1930 side still had sfp+ up and down.
It seems that it might be related EEE feature on mikrotik rb5009. Does xs1930's SFP+ support EEE?A similar issue happened on netgear MS510* switches and the diagnosis result is at: https://forum.mikrotik.com/viewtopic.php?t=185107. Basically because MS510* do not support EEE.
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
