Shutting down e.g. port 80 on cloud connected access point (NWA55AXE)
Hi Customer,
Currently on nebula we can't disable the HTTP function / port 80 of AP.
Nowadays, most popular browser will initiate HTTPS connection after we type IP address to access the AP, in addition, most people won't know each AP's IP address and even the password. So could you please share with us if there's any reason you'd want to disable this port?
Best Regards,
Richard0 -
Like you say yourself - port 80 doesn't have much use - so why have it enabled at all (by default)?
First thing to do when security hardening is to disable everything that is not used... so port 80 should not be open at all.
And just because something has a password, doesn't mean it's safe:)
Anyway, perhaps i can shut down port 80 via ssh/terminal? (i can login with the direct user/pwd).0 -
Hi sir,
You can use command through SSH to shut down the port 80, but every time you change the AP settings on Nebula, the Nebula will push the configuration to AP and overwrite the setting you’ve just set up (to be the same as cloud setting), therefore the port 80 will be enabled again.
If you do need the command, this is “configure terminal no ip http server”
Thanks for letting us know your concern, we’ll make this a feature request, and further evaluate if this will be implemented in the NCC.
Best regards,
Richard
- 588 USG FLEX H Series
- 477 News and Release
