What are GS1900-24E firmware 2.6(AAHC.3) ssh console commands?
Hi @EerWie,
I would like to inform that GS1900 series are smart managed switch which means you may only configure the switch via web GUI. If you want to configure the switch using command line, you'll need a manage switch like; GS2220 series.
Hope it helps.Jonas,0 -
Actually you could log in with ssh if enabled. So there should be the list of used commands somewhere.BR
So what is the command list?0
Hi @bensegar,
Welcome to Zyxel community!
Since GS1900 series is a smart managed switch which does not support CLI command to configure.
You may only configure the switch on web GUI.
If you want to configure the switch using command line, you'll need a manage switch like; GS2220 series..
I check my GS1900-8HP and find some commands can use, you can check my attachment.bensegar said:So what is the command list?
But GS1900 could not configure via CLI, just like Jonas and Melen said.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
