ZyWALL USG 20 can't connect to console
I've inherited a ZyWALL USG 20 and don't have the password. I found password reset instructions on the European forum here. However, that requires console access, which I have been unable to establish.
I'm trying 115200 baud, 8 data bits, 1 stop bit, no parity, no flow control as documented in the CLI Reference Guide. I've tried a USB serial cable with an FTDI chip (connected to a laptop) as well as a standard COM cable (connected to a server with a plain old COM1 port). I've restarted the ZyWALL multiple times. No matter what I do, I get a black screen in Putty or TeraTerm.
The Reference Guide says:
• Garbled text displays if your terminal emulation program’s speed is set lower than the ZyWALL’s.
• No text displays if the speed is set higher than the ZyWALL’s.
• If changing your terminal emulation program’s speed does not get anything to display, restart the
ZyWALL.
• If restarting the ZyWALL does not get anything to display, contact your local customer support
ZyWALL.
So I'm on the last step: contacting you all, my "local customer support."
Any thoughts on how to get access to this device? I don't suppose a short press on the Reset button would reset just the password? I'd like to see how it's configured before doing a factory reset and starting from scratch.
Thanks for any tips!
Hi @mcbsys,
Press reset button will reset to system default, not just only admin password. You need to set up start from scratch. Can you check Device Manager if the COM port maps to COM1?
@Zyxel_Cooldia, thanks for your reply.In Device Manager on my laptop, the USB cable usually shows up as COM5. I adjusted PuTTY and TeraTerm to COM5, but still got a black screen. On the server, the direct COM port cable shows up as COM1 in Device Manager. PuTTY was set to COM1, but still I got the black screen.0
I gave up and did a factory reset. The console still doesn't work.
Hi @mcbsys,
Not sure if it is physical serial port issue. Maybe you can try to attach console line to other device to see if it have anything output.0 -
Well, the same cable works fine with three Cisco switches. Maybe it's the physical port.
I just posted a question regarding the same type of issue. I got to the Putty black screen but no throughput to access the GUI console. The articles seem to be incomplete.
Hi @TedB,
On your laptop/PC, go to Device Manager and check which COM port is. Enter the correct COM port and speed 115200 in PuTTY.
Make sure you connect an USB serial cable to the console cable.
Click this link to start: https://bit.ly/3R2Wx52
Emily0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
