2 APs NWA50AX connected to 1 router
yes0
1 SSID yes, roaming... kinda. It will work, but the choice of keeping connection or change to another AP will be taken by the client.I don't know, however, if Nebula cloud management could "fill the shoes" of a on site wireless controller.0
Hi @relja
Yes, client can roam successfully in your topology. Just to make sure two things below:
1. Both APs need to have the same SSID with the same security settings.
2. Please don't put two APs too far away from each other, generally 15-20 meter will be appropriate.
Best Regards,
Richard0
- 588 USG FLEX H Series
- 477 News and Release
