[NEBULA] How to change location of my devices between different floor plan?
Hi JohnM
Welcome to our Nebula Forum. We have a detailed step-by-step information on FAQ to guide you how to update floor plans and distribute your devices among different floor plans. FAQ > Configurations > How to change a location of my devices between different floor plans?
The example is to upload two floor plans ZHQ A and ZHQ B at first then relocate a registered nebula device(ex:NSG100) from ZHQ B to ZHQ A. Besides, if your have more than one floor plans located in the same place, just click the "Floor plan" button on the top of the map, you will view categories of devices and device distribution among different floor plans. Last but not least, when you select one floor plan, the others will be invisible. Hope this has be useful and clear to you
Zyxel Nebula Support
hey @Nebula_James
I did try the steps you mentioned in the FAQ and I was able to place my devices, but I would say that switching between Place device on map and Edit floor plans tabs is kind of odd.
Any plan of improvement about this?0 -
Thanks @Nebula_James , looking forward for good news0
- 588 USG FLEX H Series
- 476 News and Release
