AP & mac address filtering ??
Hi @ITGS
Welcome Zyxel Community
Here is a FAQ for your reference.
[NEBULA] How to configure MAC-based authentication to enhance Wi-Fi security?
Please note that when you are setting the SSID Advanced Settings, select the SSID you need for mac auth.
You also use this FAQ
[NEBULA] How to add policy rules for clients?
Select "to specific SSID" and manage your device allow or block.Any problem can talk to us.
Thank you, have a good day.
Zyxel_Jay
Hi @ITGS
Zyxel_Jay
Thank you for reply.
Unfortunately I can't enable mac authentication. Option is grayed out.
I think that NWA50AX don't support this feature...
If this is the reason, I'm very surprise because it's a standard feature and is very limiting.
If I knew this, I did not buy this AP0 -
Thanks for your reply. Sorry for not noticing this.NWA50AX isn't supported MAC Authentication.
You can find this information with the path.HELP>DEVICE FUNCTION TABLE>SB Access Point
Nebula has the same mechanism as Mac address filtering, which you can set up using the second hyperlink from the previous article.
“You also use this FAQ
Select "to specific SSID" and manage your device allow or block. “
If you have any question,please reply me.
thank you
Zyxel_Jay
What happens if you add the device to the MAC list and set Authorized to No?
- 588 USG FLEX H Series
- 477 News and Release
