Parental control not working on VMG3625-T50B router
QwerTy
I received my VMG3625-T50B yesterday. I tried setting up parental control only to find out that you cannot set the block for two different days. In other words, I want to set out the block so that it starts on 11 pm and ends on 6 am the next day. Why is this not possible? It seems that you can only create a block for the same day. Please tell me that this is a bug and not a feature. Having it block internet access at 1 am defeats the purpose of having the block.
Found the answer here: https://community.zyxel.com/en/discussion/12998/xmg3927-b50a-parental-controlsSo basically it's as I thought: it has to be PM or AM only. I had to start the block on 10.45 pm to 11.45 pm and another block at 1 am to 6 am. You can't do 12 am because, well, that's AM and the software can't take mixing AM and PM. So this is definitely a thing that should be fixed. I don't think anything is wrong in my time settings and the router isn't showing a firmware update either.EDIT: In all fairness I must say that the speeds that I'm getting from my router are good, I'm getting exactly what I'm paying for.
- 588 USG FLEX H Series
- 477 News and Release
