ATP100W wpa ssid not working
2»
  • CcHuMi
    CcHuMi Posts: 17  Freshman Member
    First Comment Friend Collector Seventh Anniversary
    yes it is allowed and cable (RJ45) computer works well.
  • Fred_77
    Fred_77 Posts: 138  Ally Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    I assume this is the other SSID; and confirm that it works with this client?
  • CcHuMi
    Yes EFFERV_INVITE is OPEN and is outgoing on DMZ whit an ip of 10.10.10.0/255.255.255.0
    And EFFERV_PRO is WPA2_Personnal wifi outgoing on LAN1 with an ip of 192.168.10.0/255.255.255.0
  • Fred_77
    I presume you have already done this obvious test; anyway what if you change wpa 2 in open? (to create the same conditions of the other ssid)
  • CcHuMi
    you are right I have try.
    Anyway this PRO wifi works only if I set the outgoing interface to other than LAN1.
    But my requirement is the LAN1 no other one.
    I really don’t understand why on this device only it is not working.
    I have installed 6 others atp100w and wifi works as expected.
    Thanks for your time
  • Fred_77
    as far i can see your configuration is quite basic.
    Obviously we missing something. In my opinion it could be better backup the configuration, full reset and start from scratch.
  • CcHuMi
    Thanks @Fred_77 I am not physically on the site actually but I wait for Zyxel employee to analyse the problem and probably after that I will do a full clean restart.
  • CcHuMi
    Hi this is a long time post but the problem remains.
    For now Wifi is working on LAN2 and with rules LAN1 and LAN2 can communicate.
    But It is very strange.
    I cannot do a full reset for now because I am far of the ATP.
    Any other idea ?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,697  Zyxel Employee
    edited August 11
    Hi @CcHuMi
    Could you help summarize the current problem?
    Update:
    You may send me a private message when you back to us for help.
    Zyxel Melen
