NAS542 very slow and unstable file transfer
CarmineB84
Hi my NAS542 has become very slow during file transfer (usually 5 mb/s) and sometimes the file transfer stop with a error.
I tried to transfer files with terminal but it doesn't solve the problem
My FW version is V5.21(ABAG.7)
I tried to reset and initialize the nas, change to RAID5 to JBOD, change Hard Drives, nothing solve the problem
Is it a hardware problem?
If it is a hardware problem of the NAS, you should see error messages in the kernel log (which can be read by executing dmesg in a telnet/ssh shell)You are not using wifi, are you?0
Mijzelf said:If it is a hardware problem of the NAS, you should see error messages in the kernel log (which can be read by executing dmesg in a telnet/ssh shell)You are not using wifi, are you?0
You can set up a static IP on the NAS and set up the same subnet static IP address on your laptop.
e.g : NAS IP : 192.168.20.20 NAS gateway IP : 192.168.20.50, LAPTOP IP: 192.168.20.50
Connected both with ethernet cable directly, and check the upload and download speed.
CarmineB84 said:Mijzelf said:If it is a hardware problem of the NAS, you should see error messages in the kernel log (which can be read by executing dmesg in a telnet/ssh shell)You are not using wifi, are you?
If you log
When you log into the router, does it indicate that the connected NAS is actually connected at 1000 Mb/s and not 100 Mb/s?A potential auto negotiation problem. On my NAS520 this problem occurs during the daylight saving time transition.
Are you using link aggregation/port trunking? If so remove it so that the NAS can be accessed over two network ports and check that both ports have a speed of 1000 Mb/s (check the connection speed in the router).
When both ports show a speed of 1000 Mb/s you can enable port trunking/link aggregation again.
ikubuf said:You can set up a static IP on the NAS and set up the same subnet static IP address on your laptop.
Connected both with ethernet cable directly, and check the upload and download speed.0
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 459 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
