Mesh im Nebula
Roudeleiw
Roudeleiw Posts: 5
Wie stelle ich den zyxel in ein bestehendes Mesh System ein?
  • Zyxel_Bella
    Zyxel_Bella Posts: 378
    25 Answers First Comment Friend Collector Second Anniversary
    Hi @Roudeleiw
    Welcome to Zyxel community!
    If you want to deploy access point via wireless to extend coverage, setup mesh on Nebula is quite easy by just one click enabling smart mesh.
    Here is the scenario and setup guide for your reference.
    [Nebula] How to extend wireless coverage with smart mesh?
    Thank you
    Regards,
    Bella
  • Roudeleiw
    Roudeleiw Posts: 5
    Oh thanks, I'll try that in Nebula then.
  • Roudeleiw
    Roudeleiw Posts: 5
    is there also a factory default for start over?
    And for Mesh, does it use my WiFi directly?
  • Zyxel_Bella
    Hi @Roudeleiw
    You can press hardware reset button on the device for more than 10 seconds.
    Would you tell us more information or the scenario about the using your WiFi for mesh?
    Zyxel mesh requires at least two Zyxel APs, one connect to wired as root and another connect to root via wireless as repeater.
    Regards,
    Bella
  • Roudeleiw
    Roudeleiw Posts: 5
    hello,
    I only use Fritz Repeater.
    My Zyxel Zyxel Cloud WiFi 6 AX1800 Outdoor does not have a button
  • Zyxel_Bella
    edited June 2022
    Hi @Roudeleiw
    Thanks for providing the information and after learning your model, we have to have to inform you this AP cannot create mesh with other brands.
    But if you’re talking about seamless roaming when both devices can connect to wired Ethernet, normally same SSID with same security password can achieve the goal unless compatible spec issue between different brands. We suggest you can setup and try to access internet when walk between devices to check if all works fine.
    If your AP is NWA55AXE, you can register and unregister it from Nebula then it will reset to default. Thank you
    Regards,
    Bella
  • Roudeleiw
    Roudeleiw Posts: 5
    thanks will try that
Nebula Tips & Tricks
